Medion s2210 Laptop not charging
    Problem Solver:
  • 11 Answers
You power cord is not working or your battery is not charging anymore
Posted on Nov 18, 2013
How to dismantle
google for "service manual s2210" filetype:pdf.
Nov 24, 2013 | Fujitsu Siemens LifeBook S2210 Laptop AC...
Medion s2210 not charging
Replace the battery. If same problem then Motherboard Battery circuit damage. you should consider to laptop technician.
Nov 17, 2013 | Medion Laptop DC Power Jack 2210, MD4200,...
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
My laptop has died, but when i go to charge it, it is not charging the laptop up.
If you get a power light on your laptop when it is plugged in and you can turn it on then, your battery is bad.
Mar 09, 2010 | Medion md40298 Notebook
Battery wont charge and laptop wont start using
Check the pin inside the connection (end of the cord) which you put into your machine, or check if the power connection on the circuitboard is damaged (you are able to wiggle it a little bit around)
Dell computer use the pin inside the connection from the adapter to recognise if the adapter you are using is a dell adapter or not. If the pin is damaged, or you are using an adapter from another brand. You will not be able to charge, but only power your pc.
Jan 04, 2010 | Medion Computers & Internet
Wiring Diagram For Sony Disc Player
how do i install a cdx-s2210 to my 92 camry..what wires do i connect?
Jan 02, 2009 | Sony CDX-S2210 CD Player
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
