Question about Garden
Great lakes hot tub
We have a 2006 Forte Great Lakes Hot tub & believe it is leaking. How do we get the panel off & where is it located?
2 Suggested Answers
SOURCE: Hot tub keeps running all
If the system is the Jacuzzi 52221-05 system mentioned in the subject header, there could be a stuck relay causing the problem and you might need to get a spa technician out to assist you in repairing the problem. However...
If it is a Great Lakes system as mentioned in your message body, then there could be a programming issue allowing the filter cycle to run continuously. Provide a model number off of the Balboa control. Then we can provide you an instruction manual or reference card to assist you in resolving this problem. you can also search our online manuals at our website. You can find them online at:
BALBOA WATER GROUP INSTRUCTION MANUALS
Posted on Sep 21, 2011
How do Ifix a leakon a great lakes hot tub?
do you know where the leak is? diff solution based on where it is. It could be a glue joint, cracked vessel, plumbing, union, gasket, etc.
Oct 16, 2014 | Pool & Spa
Great lakes hot tub humming sound
You either have a locked pump, impeller or stripped impeller on the pump shaft. Remove the jet pump assy and repair the pump and or impeller. You can also replace the pump assy.
Apr 30, 2014 | Holmes Products HM495-UC Humidifier
The power went out in town, the power came back on, and the power is on to the hot tub, but we got an F2 code, and it isn't going on to cycle and the temp is at 54 now. What is the F2 code. We have a great...
I need to know what kind of control pack your tub has. If you can open the side panel and tell me what brand the pack is I can tell you what the error code is for.
Nov 03, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
How to Get Hot tub off sleep mode
press temp button and then the light button in sequence.
Nov 14, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Reset error code hot tub
tub is in sleep mode usually to change u must press temp button then light button you want to b on standard mode STD
Oct 04, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
