Question about Zoom Q3 Video Recorder
How to fix error on Q3 handy video recorder
It say err:35390and will not show video
Virus in Camera
Your model doesn't come with built-in storage, so that makes this easier. You should first put in another SD card and see if that helps. If it does, you'll probably have to reformat your first SD card, wiping everything on it. Sometimes formatting issues appear to Windows like a virus on an external device. If this does not fix the virus warning problem, then your virus is likely on your computer, not the camera.
A good virus scanner/remover might be in order for your computer.
Hope this helps. Good luck
Apr 27, 2014 | Zoom Q3HD 1080p Handy Video Recorder
Error message
ERR-15 hard drive error. need to replace hard drive also it would be easier if you just take it in a repair shop
Sep 10, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
How to eliminate virus in my zoom q3hd
Have the memory card SD/HC checked by any antivirus software.
Format and clear if necessary.
Rest assured. There CANNOT be any virus in your Zoom Q3HD.
Disk error
Sony handy cam dcr-sr20 HDD format ERR 31:00
Apr 30, 2013 | Sony Handycam DCR-DVD201 DVD Camcorder
Zoom Q3 ERROR 35390
I have the same problem.. Doe you have a solution yet?
Greeting from holland
Jul 20, 2012 | Zoom Q3 Video Recorder
Power button broke on zoom q3
There is a design defect in the zoom Q3 video/sound recorder. The power button is tiny and only held by three finite solder points that cannot take the regular force of one pressing on it. The solution is simple and permanent. Since the Samson tech Zoom Q3 comes part easy you have access to the part. The power switch falls of and stays inside. Get a fine tip soldering iron and resolver it, but the real trick is to put some liquid plastic support in behind the power switch and around it so that it will no longer be affected by the force of pressing it on and off. Video here: http://youtu.be/SwHJ9b6yNrc
Jul 16, 2012 | Samson Technology Zoom Q3 Handy Video...
Windows media player won't play my videos because the extention "mov".
Try VLC Media Player, which is free software that is compatible with many different types of videos. The link to download VLC can be found here: http://www.videolan.org/vlc/.
Nov 24, 2011 | Samson Technology Zoom Q3 Handy Video...
Recorder showing these words in window: ERR wish to restore it to folder index where I have important interviews filed.
The ERR indicator is only active if the DVR detects errors related to decoding of video/audio. These errors are due to discontinuities in the received or recorded file data.
Nov 05, 2010 | Olympus VN-4100PC Digital Voice Recorder
"chk" error on screen olympus vn-4100 pc
I had a similar sounding problem my Olympus VN-5000. I would turn it on, it would show "CHK" for a few seconds, and then "ERR." This persisted despite fresh batteries. The "ERR" message reportedly means a memory error. I found a solution, which appears to reformat the memory. Try to press the STOP and DISP/MENU buttons at the same time for about 2 seconds, and then the display should show "FOR". It will supposedly erase the whole memory, but will at least make the device usable again! I hope this solution works for your model...
Jul 20, 2008 | Olympus VN-3100PC Digital Voice Recorder
Zoom Q3 Video Recorder Logo
81 people viewed this question
Top Zoom Video Cameras Experts
matt
matt
Are you a Zoom Video Camera Expert? Answer questions, earn points and help others
