Question about Olympus SP-570UZ Digital Camera
My Olympus SP-570UZ doesn't turn on.
When I try to turn on my camera there is just a black screen and I constantly hear funny sound like 'click'. The same thing happens when I plug it in to the computer. It was never dropped on the floor or into water.
    Top Expert:
  • Olympus Master
  • 6,702 Answers
On top of the monitor is the monitor / viewfinder button. Little right from the centre, you can press that one to switch between picture in the viewfinder or on the monitor.
It also can be your batteries are old and can't be charged to the required charge. Or even when one is not ok, the camera can't work as it should. Try new batteries. And Olympus wants you to use only NiMH batteries. Alkeline batteries may have a much shorter service time. AA manganese batteries are not allowed in the camera and NiCD won't work at all.
When using new batteries, don't forget to charge them before use.
As a last option, it could be something is defect in your camera. (I hope not) When something is broke in your camera, or something is blocking, the current could become to high and damage the camera. Or if a gear is defect, it could cause extra damage in the camera. In all that kind of occasions the camera could play safe and not switch on to full operation.
If nothing will bring back the light on your monitor, the only thing to do is contact your dealer, and if repair should be to expensive, start saving for a new one. Sorry.
Posted on Nov 17, 2013
SOURCE: Olympus SP-570UZ-zoom error
Had 570UZ for 2 weeks and "ZOOM ERROR" occured. Seemed hopeless. Changed batteries several times, bought new Alkaline.
No change. Finally decided that it is probably a connector problem.
Turned Camera Off. Held Camera by the lense barrel. Held palm of other hand and thrust the back of the camera ( LCD side) into the
other hand. The idea being to jostle the camera contents without cracking the LCD. Did this a couple of times, turned camera on and it works fine. At least for this evening. At least for now it seems like a classic component connector problem somewhere inside the camera.
Posted on Mar 15, 2009
  • 11967 Answers
SOURCE: Zoom Error with my Olympus SP-550uz
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 04, 2010
lock123
  • 6831 Answers
SOURCE: Problem with my Olympus SP-570UZ- zoom error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Obertelli
  • 3006 Answers
SOURCE: what is the price of
Prices vary worldwide, and you haven't stated where you are nor which currency.
Also, the camera you refer to is a long discontinued model, so if it's new and in a shop you should haggle hard for a discount.
If you're asking what your used camera is worth, then it;'s impossible to give an answer. Condition is everything, and it's best to have the original box and all accessories. Even then, it's only worth what someone will pay for it on the day that you sell it.
As a guide, on eBay in the UK a good and fully functional example without the box and accessories tends to sell for about £60 although one recently went for almost £100. Expect those prices to be slightly lower in the USA, a lot lower in the Far East and slightly higher in mainland Europe.
Posted on Jun 21, 2011
SOURCE: My Olympus FE-4000 camera lens
Mate if your desperate you could try to take off the top of the camera shell (where lens is) and see if you can straigthen up the lens by the screws holding the lens in place. PLEASE try this at your own risk. I have the same problem but would rather go to an expert.
Good luck
Posted on Dec 10, 2011
How to open olympus sp 570uz
Not quite sure what you mean by "open," but you can find the manual for this camera at: Product Support
Apr 02, 2015 | Olympus SP-570UZ Digital Camera
Olympus SP-720UZ screen turns on but remains black
Sounds like a hardware problem... You may have to take the camera to a dealer and have them check it out. However, try this first:
Leave the card out for a while, and recharge it. Then reset the camera to factory defaults is you can (check manual).
You may also want to check with the Olympus web site to see if you have the latest firmware update to your camera model. You could try and download latest version and install it.
Hope any of this is to some help... :)
Mar 31, 2014 | Olympus SP-720UZ Black Digital Camera...
Will an 8gb memory card work in an Olympus SP 570 UZ camera
No. This camera works with xD Picture Cards up to 2GB in size.
Mar 10, 2013 | Olympus SP-570UZ Digital Camera
Battery level quickly empty
I recommend you to buy a new battery. If this doesn't work. Just buy a new Camera, because the engine probably broke.
Dec 28, 2011 | Olympus SP-570UZ Digital Camera
What size uv filter do i need for an olympus sp-570uz camera ?
The SP-570UZ does not have a filter thread; therefore, lens filters cannot be attached directly to the camera.
Filters with 55mm diameter can be attached to the SP-570UZ via the CLA-10 Lens Tube Adapter, sold separately. However, it is not recommended because vignetting may occur in the corners of the image when the camera is set to wide angle positions.
The CLA-10 Lens Tube Adapter (Item #202104) is available from authorized Olympus dealers and also online from The Olympus Store: http://emporium.olympus.com
Apr 26, 2010 | Olympus SP-570UZ Digital Camera
Movie/record seting
Have a look at page 45 of the user manual - see link below - instructions on how to to tune the sound on/off when taking a movie
Apr 07, 2010 | Olympus SP-570UZ Digital Camera
Xd card will not lock into slot onto olympus sp-570uz
The bad news is that xD is slow and only used by Olympus and Fuji, with Fuji in the process of abandoning it. Eventually Olympus probably - hopefully.
Your camera is better off using a sd card. Try that.
And, could it be that your camera only takes a sd card?
Oct 25, 2009 | Olympus SP-570UZ Digital Camera
Hello
Regards
Andrea
Jan 06, 2009 | Olympus SP-570UZ Digital Camera
Oct 30, 2008 | Olympus SP-570UZ Digital Camera
Olympus SP-570UZ Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
