Question about Frigidaire Energy Star Room Air Conditioner
Fridgidaire window heat cool unit not heating
Cools great, fan works great, when switched to heat once in a blue moon the compressor will kick on and give us heat for as min or two. condenser is clean, compressor doesn't appear to be even trying to start.
  • 739 Answers
Check the reversing valve and solenoid
Posted on Nov 20, 2013
4 Suggested Answers
  • 20 Answers
SOURCE: Frigidair HVAC not cooling; Believe its a emergency heat problem
the switch is on your thermostat - look for something that says "system" or "Em heat, heat, off, cool" switch it to "cool" and enjoy. If that doesn't work, call a HVAC service tech. You could have bigger problems than just the system switch. Good luck
Posted on Sep 06, 2009
multilinkent
  • 739 Answers
SOURCE: My AC, Model# FAS256R2A, IS
Hi
look at your problem, very similar to the issue with my unit for a moment before.
Posted on Apr 06, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: heat stays on even when temp is cool and compressor doesn't work
    Have a professional diagnose the communication between the main control board, and the timer.
    Posted on Aug 17, 2012
    Split AC whole unit turnig off at each compressor start up!
    Dirty coil wash outside unit with water and change indoor unit filter
    Jun 08, 2017 | Heating & Cooling
    Have an lg reverse cycle was sitting for 12 months. the fan works fine but cooling or heating is not working.when i first turned it on it took about 5 minutes then compressor kicked in once in got to...
    I think, your compressor gets over heated due to condenser block-clean it. Less rpm fan speed. -Replace capacitor. 3.Check compressor running capacitor. If weak replace it. Helpful?
    Dec 29, 2010 | LG Heat cool Window Air Conditioner
    We gave a Goodmn Hertz 60 Phase I heat pump - installed this summer....worked great for cooling..now that temps are dropping we are needing heat. When we turn it on it comes on but never heats. Think it...
    If you changed the unit but didn't change the thermostat it is possible that the thermostat that you have will not work with that unit. I see that the unit you installed is a heat pump, you may have a straight cool T-Stat. If you put the T-Stat in the "Auto" "Heat" mode the outdoor fan and the compressor should be workng as well as the blower fan. If it turns out that the outdoor fan and compressor are not running you will want to buy a Thernostat that is compatable with heatpumps should be 2 heat/ 1 cool
    Nov 05, 2010 | Goodman PHKJ048-1 Air Conditioner
    Compressor not kicking in on 'cool'; or ;dry'
    Have you checked that the controls are not set to fan only? If you have lets go to the next step. All window A/C have thermal switch.. These thermal switch keeps the compressor from overheating. In the event that the compressor is overloading it would trip then click back on as the compressor cools down. Sometimes those switches go bad but the compressor is ok. They are mounted on the compressor themselves and accesable once the A/C unit cover has been opened.
    Jul 07, 2010 | Whirlpool ACQ122XK Air Conditioner
    LG 8008R compressor runs one minute then fan blows 3 minutes
    You need to have an AC tech come out and do some preliminary testing on this.
    May 12, 2017 | LG Heat cool Window Air Conditioner
    Kenmore a/c window unit fan not kicking on with compressor.
    Likely a bad motor, when this occurs verify the board is sending voltage to the motor.
    May 30, 2017 | Kenmore Heating & Cooling
    Split unit, I get heat but no cold
    I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
    May 16, 2009 | Fujitsu 24R1 Air Conditioner
    Will not switch to cool mode. heat and fan work fine
    hi,
    regarding on switch mode theres a common line between heating and cooling although fan is always connect on them.,also with the thermostat,the sequence on this when you switch to cooling and your connection is on heater,the contactor will shift to compressor source,so if there is no cooling, the contactor supplying the compressor is not functioning when you switch on cool mode.try to tighten screw on compressor relay maybe only loose.on control panel,or check continuity of compressor if the compressor still good,check also the freon charge using clamp ammeter,this should be done by ac technician.have a nice day
    rate me up,thank's
    Apr 26, 2009 | Heating & Cooling
    Ruud heat pump outside fan
    You may be right in looking at the motor. It uses a different speed on heat than cool. The heat cycle uses low speed, usually red. Some manufactures use blue (medium). Cool uses black, high speed. If you are confident, switch the low speed wire with the high speed and see if this changes anything. If the fan motor isn't the problem, check the other setting (cool) if the overload trips, you may need to look into a new capacitor or compressor, if so, you can install a hard start kit. these are start boosters, and are inexpensice, sometimes they will give another year out of the comp. but I've put them on and they have lasted 5 years.
    Mar 15, 2008 | Heating & Cooling
    Frigidaire Energy Star Room Air Conditioner Logo
    105 people viewed this question
    Top Frigidaire Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Donni Steen
    Bill Long
    Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
