Question about Origin Domination - Massive Assault Rsurrection (French Version Only) (PC )
Domination - Massive Assault won't start in windows 7
Windows 7 does not support the game , only xp or elder versions, have any patch to fix it?
Swarm Assault's color scheme is corrupt on Windows 7.
I have the game too, played it on Win 95/98. You can do those for compatibility mode, or XP SP2/3.
Under that is the Settings. You can check all those options there (that's how I did it) and just run it with administrator mode.
There you have it, it's fixed, only problem I'm facing now is the blinking "windows circle" from the start bar. That is all.
Mar 06, 2012 | Gate 5 Creations Swarm Assault
CANNOT PLAY BICYCLE PINOCHLE SINCE UPDATING COMPUTER PLAYED BICYCLE PINOCHLE ON WINDOWS 98, CANNOT PLAY ON WINDOWS 7
Unfortunately, due to changes in the OS and how programs run, a program written for Windows 98 will not run under Windows 7 directly.
Even the compatibility mode will probably not work unless your version of Bicycle Pinochle for Windows was written for XP as well as Windows 98. (The WinXP version would possibly run under the Windows 7 32-bit version; it won't work under the 64-bit OS. To find your version of Windows 7, click Start > Control Panel > System and Security > System. If the version title ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit version.)
You need to either upgrade your game software or get an older version of Windows running somehow. This could be a virtual computer (runs inside your Windows 7 computer if your hardware permits it), a second machine or a dual boot computer. For Windows 98, you will need a licensed version of the OS for any method. Check a nearby Windows User's Group to see if anyone there has the OS.
If your version of Pinochle could run under Windows XP and you have Win7 Pro or Ultimate (or upgrade to them), you can run a virtual version of XP for free. In this case, download and install (in order) Virtual PC and XP mode from Microsoft. Then install the software in the XP computer as if it were the only computer running. (The compatibility mode didn't work inside XP mode for software written for Windows 2K so I doubt a Win98 program will work.)
An XP version of Bicycle Pinochle was offered by Microsoft: http://www.microsoft.com/games/bicycle/card/ . A Windows 7 version of Single Deck Pinochle is here: http://www.sac-irca.com/pino.html .
I wish that I had better news for you.
Oct 23, 2011 | Expert Software Bicycle Pinochle for...
Purchased Doom II, Ultimate Doom and Final Doom, but switched to new computer with Windows 7. Now these programs don't work.
The only thing you can try is the "Compatibility Mode" option in windows 7. Right click the executable for your game and choose properties. Go to compatibility tab and choose a lower version of Operating System (e.g. Windows XP SP2) that supports your game. Save the changes you made by clicking on OK and try the game again. If this won't work, there is no other way but to use another computer with a compatible OS or downgrade your OS to a lower version that works.
You might also want to check your game manufacturer website for any update or patch that you can use to make the game compatible for Windows 7.
Hope this helps.
Jul 30, 2011 | Computers & Internet
New computer has windows 7. When I try to use Word Whomp disk it tells me it is not compatible. Is there a patch I can get?
I can't seem to find a patch but try right clicking on the program, going to properties -> compatibility and running it in XP or Win 98 compatibility mode.
There is actually an online flash version:
http://word-games.pogo.com/games/word-whomp
Hope this helps!
Jul 04, 2011 | EA - Electronic Arts Word Whomp To Go for...
I downloaded swarm assault. It's a pretty old game. I have windows 7 and a very up to date gaming computer. whenever i play swarm assault the graphics are wrong. it's all inverted. Is there any way to fix...
Each version of Windows has a 'compatibility' mode to accommodate games written for earlier versions. Open your Windows Help menu and just type in 'compatibility' as your search word. 7 has some major changes compared to earlier versions and it may not be possible to 'backdate' for your game but it costs nothing to look.
Apr 13, 2011 | Gate 5 Creations Swarm Assault
I have Curse: The eye of Isis, and it dosnt work on my windows 7/ home premium. Is there any patch I can get?
DreamCatcher no longer lists this game at their site: http://www.dreamcatchergames.com/dci/pc.php . So there are no patches available in the support site.
Curse: The Eye of Isis was issued for XP and older versions of Windows. The installers and drivers are totally different with Windows 7. What version of Windows 7 Home Premium do you have? If you have the 32-bit version, the compatibility mode might work. (It is less likely to work with 64-bit Windows 7. However, there are no guarantees for either version.)
To try using the compatibility mode: right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Make sure the program is running in the compatibility mode if it does install by doing the right click and Properties step again.
A method that will work but will cost more money is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you buy an upgrade to Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the software from your CD in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS.
I hope this helps.
Apr 04, 2011 | DreamCatcher Interactive Curse: The Eye Of...
My rollercoaster tycoon game does not work on my newer windows computer .I believe it is running windows xp. The screen is **** strangely when I run the game. The top part of the screen appears at the...
It wasn't built for later versions of Windows. You will need to download the latest patch and troubleshoot the compatibility. Here's some information from Microsoft to get your Roller Coaster Tycoon working on Windows XP:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/daniels1.mspx
If you're running Vista or Windows 7, just right click on the file, then click on Troubleshoot Compatibility.
Dec 27, 2010 | Hasbro Interactive Roller Coaster Tycoon...
I can't install the patch for Airport tycoon. it says "1628 failed to complete installation"
try uninstalling the game and reinstalling it, then applying the patch. see if that fixes the problem.
Aug 14, 2010 | Global Star Software Airport Tycoon 3 for...
I cant play on my pc for some reason it says "oblivion has encountered a problem and needs to close" why is this?
It is usuall one of a few reasons:
  1. Your system may not meet their minimum standards.
  • Minimum System Requirements:
    • Windows XP, Windows 2000, Windows XP 64-bit
    • 512MB System RAM
    • 2 Ghz Intel Pentium 4 or equivalent processor
    • 128MB Direct3D compatible video card
    • and DirectX 9.0 compatible driver;
    • 8x DVD-ROM drive
    • 4.6 GB free hard disk space
    • DirectX 9.0c (included)
    • DirectX 8.1 compatible sound card
    • Keyboard, Mouse
  1. You need to update the game or download a patch.
  1. You may need to scan your computer real good for a virus.
If all else false un-install it and re-install it. let me know if these help you.
Sep 09, 2009 | Bethesda Softworks The Elder Scrolls IV:...
Origin Domination - Massive Assault Rsurrection (French Version Only) (PC ) Logo
100 people viewed this question
Top Origin Video Game Consoles & Games Experts
John Anderson
John Anderson
EnergeeUK
Level 1 Expert
Laxman Bisht
Laxman Bisht
Are you an Origin Video Game Console and Game Expert? Answer questions, earn points and help others
