Question about Fine Mesh Grille Fiat 500 12-13
How to turn inertia switch back on after crash fiat grande punto
Had crash fuel cut off now wont come back on
Where is inertia switch on Fiat fiorino 2015 model Car was involved in a minor accident. It cuts fuel supply and wont start
Try the trunk, right side behind matting or panel. Or the right side front outer kick panel.
Apr 09, 2017 | Fiat Cars & Trucks
Have fuel cut off on dashboard on 59 plate fiat grande punto
fuel pump
fuel relay
not enough fuel in tank
Oct 31, 2016 | Fiat Cars & Trucks
Glove box fuse box diagram for fiat punto grande 06
On this website (link below) you find fuse box diagram and description for Fiat Grande Punto
Fiat Grande Punto 2006 2012 fuse box diagram Auto Genius
Feb 04, 2014 | 2006 Fiat Grande Punto
Fiat grand punto duel logic wont go into automatic mode
had same problem with my car ..i took it to semi auto specialists! there was a error on the cars computer which they deleted free of charge ..& hey auto mode back on!
Jul 08, 2012 | 2006 Fiat Grande Punto
How do you get a Fiat Punto (2002) fuel cut off switch to stay down? Time for a new one? Or quick fix?
this works like a trip switch ,,, are you sure there is no electrical fault??? if the electrics are ok i would replace it ,,,, it is possible to bypass this but its not recomended because if a fault occurs in the future there will be no trip switch to break the circuit and this means petrol will keep being supplied and in a crash that could be a fire hazard ,,, so for safety retain the system as it is designed,,,
Feb 11, 2012 | 2002 Fiat Punto
My fiat 2002 fuel cut off switch won't stay down - time for a new one? Or is there a simple fix?
Sorry but the only fix is to replace it, the internal locking pawl is probably worn.
Engine wont start help please!!!!!
you have tripped the inertia switch, (there to cut off the fuel pump in the event of a collision), you need to reset the switch by simply pressing it back in.
Mar 08, 2010 | 2006 Fiat 124
Fiat punto cant start now afer it suddenly cut off
hi sounds like fuel cut off switch was activated,any more information would be helpful
Aug 11, 2008 | 1990 Buick Reatta
Fine Mesh Grille Fiat 500 12-13 Logo
71 people viewed this question
Top E&G Classics Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an E&G Classics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
