Question about Elna Sewing Machines
Elna motor problem
I am not sure if question was received. When starting to sew or wind bobbin screen displays: turn machine off motor not working.
    Champion:
  • 241 Answers
Turn the handwheel to see if the machine is jammed. Does the motor make any noise when you push the foot control? It may be necessary to open the covers to see if the belt has come off the motor. It could need a new motor, cable or circuit board.
Posted on Nov 18, 2013
  • S A Helm Nov 20, 2013
    thank you!
4 Suggested Answers
Tally Girl
  • 1122 Answers
SOURCE: My elna sewing machine bobbin
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Posted on Aug 02, 2011
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
My elna 7000 sewing machine does not want to wind the cotton
Not sure of the particular bobbin winding problem you are experiencing. However, frequently the bobbin winder "tire" becomes worn and needs to be replaced.
Elna 7000 Parts
What is the correct way to wind and insert bobbin in elna machine
Jul 20, 2016 | Elna Sewing Machines
Why does display read "WINDING BOBBIN" and won't clear?
This video may help:
Winding an Elna bobbin
Perhaps the bobbin winding mechanism has not been released. (She unsnaps the bobbin when finished winding.)
Aug 31, 2015 | Elna Quilter's Dream 6003Q
How to wind a bobbin on a 2004 elna sewing machine?
1 - Look in your book.
2 - Ask a sewer to show you.
3 - Google
Jul 16, 2014 | Elna Sewing Machines
What is the correct way to wind and insert bobbin in elna machine?
You always wind the Elna 7 hole bobbin with the holes on top, and load it into the bobbin case the same way, this means when you draw the bottom thread off the bobbin, it will turn anticlockwise.
Apr 30, 2014 | Elna Sewing Machines
After I "undid" winding my bobbin, the electronic display still showed the symbol for winding bobbin and the machine will only sew straight. None of the other buttons like back stitch or change stitches...
are you sure you've moved the bobbin winding mechanism back to the right spot? if its still pushed over against the bobbin spool holder it may be stopping the normal functions from working. If that isn't the problem then it may be something for the tech at the Elna dealers.
Sep 10, 2013 | Elna Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
ELNA 7000 no display on screen
Problem solved - I have a useful son! he took off the casing & cleaned 'circuits' . Now works fine. Wendy
Jan 30, 2010 | Elna Sewing Machines
I was given an Elna Supermatic 722010 and am not sure how to wind the bobbin.
A link to a supermatic manual is here
http://www.arizonaexpressionz.com/elna_instruction_manuals/Supermatic.pdf - I suggest you download this and print it out as this machine is over 50 years old now and manuals are scarce.
Disengage the clutch by holding the outside of the fly wheel and turning the inner knob of the wheel towards you.
You need to take the thread from the spool across to an eyelet on top left, then back to the bobbin winder, up through a hole in the top of the bobbin and hold the thread tail. Flick the bobbin across against the stopper. Now press the presser foot or knee control to start the motor. Hold the thread tail until youve got coverage across the bobbin enough to hold the start, then stop winding and cut the thread tail with scissors. Now continue winding but put the handle of your scissors on top of the thread spool to stop it bouncing and ensure your thread winds smoothly and under tension.
Watch the bobbin fill and give the thread a nudge to fill top and bottom as well as the middle evenly, you want a nice even wind. Fill to 3/4 and stop, flick bobbin back off the stopper, then cut the thread. Remember to re-engage the clutch by reversing the first step.
This is a lovely heirloom Elna machine - you need to thread the bobbin as the manual describes and get the thread into the tension spring. Please read the manual information on oiling too, this machine needs to be oiled on the red spot locations every time you use it according to the manual, use good quality clear sewing machine oil for this purpose.
Oct 21, 2009 | Elna 2007 Mechanical Sewing Machine
Bobbin winder is stuck
It seems that the bobbin winder sensor needs adjusting and is best done by a service technician with the appropriate service manual to ensure correct parameters are achieved..........to locate your nearest Elna dealer, try ElnaUSA .....here
Feb 16, 2008 | Elna Quilter's Dream 6003Q
Sewing Machines Logo
81 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
