Question about Eltax Liberty 5+ Main / Stereo Speaker
Eltax Liberty Centre not working
I recently purchased eltax libery centre, the tweeter works fine but both subs dont work at all, ive tested them and no joy, is there a way to repair them myself?
4 Suggested Answers
SOURCE: Eltax speaker problems
I agree, NE Speaker is the BEST repair speaker shop in the eastern half of the USA. I have an EV 12" speaker re-built there and its better than it was before it was blown. Great job NE Speaker!!!
Leo B.
Posted on Oct 31, 2008
issken
  • 1472 Answers
SOURCE: Ive just bought an eltax system, I have no
pete0760
I was having trouble finding a manual on your sub as will but found a picture of the back and wanted to confirm this is what yours looks like.
If this is what you have then you have a sub for a 2.1 system. Note you can connect it to a system that has more speakers like a 5.1 or 7.1 system but you would just tie it into the front speaker.
As for the normal connection, the speaker wire connections are for the satellite speakers for the front change only. Note you can connect a second pair of speakers to make a 4.1 system. Then you would connect the speaker channel on your receiver to the "Line Input".
If your receiver does not have speaker wire connections on them (most modern ones do not have them) then you can get adapter cables at your local eletronic store. Most of them will go back to an RCA cable.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Nov 05, 2010
  • 4 Answers
SOURCE: how to setup an eltax
Well, that is pretty dependent on the room size and seating position. Ideally the center channel should be directly under the TV. This is where 90% of the dialog will come from. The two tall speakers should then be placed adjacent to the TV, preferably a couple of feet away. The smaller surround sound speakers should be approximately ear level, to slightly above and behind the viewer. The surround speakers are bipolar, so they will radiate sound out of each side, therefore you do not need to "angle' them towards the listener. The sub woofer doesn't really matter, the bass frequencies are non-directional. I like to hide it under a table or something like that.
Some new receivers have built in surround set up programs that will send a test signal to each speaker and "listen" then adjust the delay and volume accordingly. Without that it will take some trial and error to get any system dialed into the perfect settings. Then what may be ideal for one specific location will sometimes not sound as good from another in the same room.
Good Luck.
Posted on Dec 24, 2010
I have a replacement tweeter for an Eltax Liberty 5+ floorstanding speaker. I have removed the screws that hold the old tweet in place but can't seem to remove it? Any tips please?
Hi, The hole that was cut for the tweeter is holding the magnet. It was tight going in. And hard to get out. Take a flat screwdriver and pry up one of the edges a little. Then go to opposite side and pry up a little bit. You may need to put something in the gap of the first side you pry up so it doesn't go back in. Once you have both sides up a little bit. You should be able to grab ahold of it with your fingers and remove it. May have to move it back and forth .
Apr 02, 2015 | Eltax Audio Players & Recorders
Hi I have a eltax impact 10 and when I turn it on and put music on it cuts straight out power still on just sub stops working can any 1 help into diagnosing the problem ? Cant afford a new 1 and u can't...
Test the voice coil of the sub with a digital multi-meter. Make sure it is within spec. They are usually 4 or 8 ohms. If OK, the plate amp is shot. They are not worth repairing. Good replacement amps can be bought from Parts Express for as little as $100 or less.
Nov 25, 2013 | Car Audio & Video
How to setup an eltax surround system? what exact place do I put them (also behind me)? It contains 4 speakers, 1 sub-w, and 1"tweeter/high range" to put on your tv. I thank You sincerely!
Good Luck.
Dec 24, 2010 | Eltax Chroma 5-Pack System
Loud boom when going in standby mode.
i would check your sub connection also make sure the volume isnt set to high. sometimes unplugging the power and cables also helps
May 20, 2009 | Eltax Atomic A-8.2 Subwoofer
No sound from top speaker
Yes Eltax will sell you a replacement part. THey also sell the woofer/driver as well. Changing either is simple. You will need a Torx screwdriver to unattatch the driver from the box. Then just pull it out, and attatch the connectors to the new tweeter. Make sure you get the wiring right for polarity. Ie look at the writing on the back of the tweeter and keep the wires going to the same connections on the new one. Screw it back in...and you are done. I have a pair of these as well, and have just done the same replacing both woofers that had been pushed in my my niece and her inquisitive hands !
May 17, 2009 | Eltax Liberty 5+ Main / Stereo Speaker
Eltax millenium 500 speaker problem
Some high end speakers have a fuse to protect the tweeter (treble). Reverse the speakers. Does the problem follow the suspected speaker? If so, the defect is most likely on the crossover inside the speaker.
What do you mean by best place to locate parts?
Apr 16, 2009 | Eltax Millennium 500 Speaker
Eltax DR-110 Sub-woofer issue
Where have you connected the sub's leads?
Feb 26, 2008 | Audio Players & Recorders
I can't hear any speech when I play a DVD, but I have all other sound.
Yes what you heard is correct,look for center speaker connection.If it is correct then connect it thru coaxel or digital out and see.
Feb 09, 2007 | Eltax DV-100 DVD Player
Eltax Liberty 5+ Main / Stereo Speaker Logo
76 people viewed this question
Top Eltax Audio Players & Recorders Experts
Trippy Tripp
Tom Chichester
Bill Willard
Bill Willard
Are you an Eltax Audio Player and Recorder Expert? Answer questions, earn points and help others
