Hello I have a RCA HDTV m50wh74xy1 problem is I keep having to replace the lamp,each time I replace it (lamp) it might last for 3 months I would like to no what is causing the lamp to blow out
I have replaced the lamp on this set at least three times but for some apparent reason the lamp keeps blowing out
  • 3,904 Answers
This could be difficult to find but most likely a grounding/shorting issue. I would start by checking the power supply and the leads coming off of that.
Posted on Nov 18, 2013
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: RCA MM52110 FUSE keeps blowing
should be covered under your insurance might give them a call.
other wise i would check the bridge rectifier,
Posted on Dec 05, 2007
  • 3 Answers
SOURCE: blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Posted on Mar 10, 2008
SOURCE: tv lamp keeps blowing out
You have a Ballast not working properly, basically the driver of the ballast is damage, that is causing that the ballast works with unregulated voltage (by meaning it goes u and down on the volatage limits), causing a faster consumed of the lamp. (Is like driving your car in a city you need to slow down accelerate, etc. and in a highway you maintain a speed and the gas last longer then driving at city).
You can get the ballast from samsungparts.com or i have bought some from discount-merchant.com at cheaper price and still good
Posted on Jun 24, 2009
On RCA HDTV wh74xy1 lamp blows out every three months
fan has a lot of dust on it.get a can of air take lamp housing and hold fan fins and blow off dist also there is a nothe fan on dlp chip.in front. take of lower back cover easry to do.good luck
Nov 17, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 52hm95 lamp breaks after only weeks of use
It is as far as the set is concerned, it sees the lamp not on.
Most likely cause would be the lamp ballast that drives the lamp.
Dec 20, 2012 | Toshiba 52HM95 52" HDTV Projection...
My 42e2000 just said "lamp at end of projected life". I have had this TV for several years, have had it isf calibrated 3 times (the last time was 1 month ago). At that point, the technician said everything...
I recomend chnge the lamp now to avoid ballast problem after.and remember reset the lamp timer after change.for reset lamp timer press menu in the remote control ----setup------in the color adjust side find lamp reset ----a change a new lamp question appear--push yes and ok.
Apr 09, 2010 | Sony KDF42E2000 42" HDTV
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
MY 50" DLP RCA picture goes on and off again. I still have sound, but it seems like it keeps wanting to reset itself. The lamp is only 15 months old! This problem is interminent. Some days not at all, and...
Is the cooling fan working? If the fan is not working lamp may be overheating. Check to make sure the fan is working. I believe the fan should be on all the time.
Sep 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Just replaced bulb to a phillips, lasted one month
Most systems with lamps will have a timer. If the timer gets to a certain hour the set should warn you to replace the lamp. Once you do, you have to reset the timer. If it gets to the max it will not allow you to turn it on till the timer is reset. Check your manual or call the mfg. to see how to reset. Sometimes it's the volume up and down at the same time or menu and power at the same time. They are all different so if you have no manual it's best to call tech support to get the reset steps.
Jul 17, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Bulb keeps burning out
There are several reasons for short lamp life. Inadequate ventilation or clogged cooling fans, a bad lamp driver or lamp ballast (they are the same) and the use of non-original Sony lamps, as the aftermarket replacements are known problem causers. Remember too that the number of times the lamp is turned on and off is a BIG factor in how long the lamp will last.
Nov 13, 2008 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Picture turns on and off
Just found this trying to figure out what was wrong with my same model tv. Since mine was under warantee, I had the repairman troubleshoot it. He changed the lamp and the tv started working normally again.
I didn't understand how the lamp could be bad if it lit up while the tv was on. He said the tube was probably using too much voltage or too little voltage to run, so the tv would turn itself off and on in an attempt to receive the correct voltage from the lamp.
I realize this is 9 months late, but maybe it can help someone else who has this problem. I can't believe there are only 3 rca dlp's out there with this problem.
Mar 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
