Question about Electronics - Others
Honda eu3000is. Run rough until i pull out the choke about half way. Then runs grear. It has done this since it was new. Now about six years old. It has low hours. I just cleaned and rebuilt the carb and replaced the air filter. I'm. Worried about excessive carbon build up. Any ideas.
  • Stuart ivimey
    Stuart ivimey Nov 18, 2013
    Artfaye - Gas is 2 months old. Using ethanol blended fuel. That's the only type we can buy here in the Peoples Republic of Massachusetts.
  • 27 Answers
You didn't say whether you were using old gas or fresh or whether you were using ETHANOL gas but It sounds like a bad gas problem. Get some fresh, high test gas and try that
Posted on Nov 17, 2013
I just cleaned the carb and now it starts and runs fine, but starts burning oil after a couple of minutes. Did I get it wrong on assembly?
There is a series of spacers and gaskets that go on in a specific order. I can't remember offhand. If you get them on wrong it can mess up the alignment of the choke control which causes it to bind up and not move freely. That can make the engine run rich and smoke which makes it look like it is burning oil.
Check online for an exploded view of the gaskets and spacers along with the bracket for the choke control. Make sure they are aligned properly.
Sep 15, 2015 | Honda EU3000iS Inverter Generator
Honda eu3000is does not operate without choke
It sounds like your fuel mixture is too lean, closing choke is richening the mixture, by closing off air
Nov 10, 2013 | Honda Electrical Supplies
Honda EU 3000is only runs on half choke
Overhaul the carb. When you have to choke it to run, there is not enough fuel getting in
May 04, 2013 | Honda EU3000iS Inverter Generator
Runs rough unless you choke while driving,leaks gas out of 1 of the carbs on rt. side
That is one of the best signs that the carbs need rebuilding and cleaning. On a Valkyrie there are SIX carbs. Take it to someone who knows what they are doing. When it's done Hang on it will run like new.
Mar 09, 2011 | 1998 Honda F6 C Valkyrie
Wont run off 1/2 choke
I had a problem with a honda generator that would only run on full choke. I removed the carburetor and cleaned the main jet with a wire and carb spray. Problem solved. Fuel stabilizer should be used with todays gas mixtures that have ethanol in them. Hope this helps.
Aug 29, 2010 | Honda 6370C - Parallel Power Kit For ...
EU 3000is generator is running rough with Eco Throttle on
The air intake system on this unit is highly fine tuned. Make sure all covers including front battery cover, plenums, air intake system is properly installed and that any and all gaskets on doors and covers are not damaged.
Oct 01, 2009 | Honda 6370C - Parallel Power Kit For ...
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Honda EU3000is generator will not start with electric starter.
I'd say your battery in the generator is going bad or bad. They are very small and do not hold a charge for very long. The noise you heard was probably the starter shaft hitting the flywheel cogs. I doubt any harm was done as long as you did not repeatedly try to start it with the key. Why Honda put a battery in these is because they are intended for use in a campground setting, where they would be used on a daily basis and the battery would constantly charged. Whereas people like us buy them for emergencies only, they sit for long periods, and the battery goes flat, and the fuel clogs the carb and we get the surging issue. That's my 2 cents. When I brought mine home new, I Sta-bil'd the heck out of the gasoline, this past winter, on start-up, the unit surges. Of course the battery was flat.
Mar 08, 2009 | Honda 6370C - Parallel Power Kit For ...
Electronics - Others Logo
132 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
