Question about Miele Ovens
Shorting out oven
My miele combi/microwave keeps shortening out and tripping electricity...
  • 23 Answers
SOURCE: oven
if it trips out after a few seconds then then you need to rewire it
if it trips out as soon as you turn it on then a cable has come loose and is touching either another cable or the metal casing in which case if you cant find it you may need another oven
it should be on a 32amp breaker with 6mm cable if its a long distance from mains to oven it should be 10mm cable covered by a either a 32 amp or 45 amp
Posted on Mar 14, 2009
IbuyUSA
  • 9 Answers
SOURCE: Miele Microwave Oven M636 EG
Use Miele UK
http://www.miele.co.uk
click Customer Support
then
click Operating Instructions
select File;
  • M616, M626, M636
free download PDF format
Posted on Oct 19, 2009
SOURCE: miele steam oven keeps wanting to be descaled after descaling!
Ours does too. Did you ever get it fixed?
Posted on Feb 21, 2010
SOURCE: fan Oven keeps tripping the electric box
keeps triping main fuse box off
Posted on Mar 20, 2010
SOURCE: does a rational combi oven have a cut off switch ?
they have a high limit for both boiler and hot air, and over current(motor)!! it sounds like you may have blown a control fuse!
Posted on Dec 21, 2010
Why does the cooker keep tripping the electric power?
loose wire,shorted switch?(You will receive an answer like this if,you did not include the make or model or serial number or
date of manufacture or complete problem and what needs to be done.)
Jun 08, 2015 | Ovens
Hi my Bosch Quantam speed microwave keeps tripping the electric when the oven is used. The grill and microwave settings both work fine. Any clues. ??
Yes, sounds like your oven element may be faulty and needs testing/replacing etc. However microwaves are best left to the qualified engineers. When you remove the cover, certain parts inside the microwave may still have live current present even with the plug disconnected and could cause serious injury or even electrocution!!
Oct 25, 2014 | Ovens
I have a Miele H147-2mb combi oven. If I start microwave in the 900w mode for a little bottle with milk i see a flame on the topplate of the oven. It's a circle with a diameter of 5 - 10 cm.
Hi there - the cover plate is most likely to be damaged or theres dirt build up behind the cover plate causing it the arc or short to the frame...
Worse case is the microwave cannot be used as it will cause more damage to the oven.. there are a few screws holding the cover plate to the top - remove it gently - if not damaged as its made of fibreglass you may be able to re-use it - inspect the hole/microwave entry for the damage caused by the arc reactions.
Pending on how bad it is - you may just have to use the oven only as one needs to replace the entire casing to overcome the problem which is costly. Wipe the carbon off the oven with a damp cloth - please don't scrap it off as it will enhance the arcing and if the damage is already excessive then reside to using the oven only.
Good luck
Aug 18, 2011 | Miele H147-2MB Electric Single Oven
RATIONAL COMBI OVEN ELEMENT GLOWING RED -IS THIS NORMAL?
your oven is electric yeah? the hot air element shouldnt be glowing like that, it glows with the door open? the oven has a over temp stat so if the oven got too hot then it would trip out, if it does then the solid state relays will have to be changed, but if it carries on as normal then shouldnt worry
Feb 05, 2010 | Ovens
Difficulty in cleaning my Miele combi oven
I have the same cleaning problem as Denise503 with her Miele combination oven - help if anyone has a solution - I have got to the stage where I don't want to use it.
Apr 10, 2009 | Ovens
Use Miele UK
then
select File;
  • M616, M626, M636
May 02, 2008 | Miele DG 4080 Stainless Steel Electric...
Ovens Logo
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
