Question about Acu-Rite AcuRite IndoorOutdoor Wireless Thermometer with Two Receivers
OUTSIDE TEMP IS NOT SHOWING
OUTSIDE TEMP NOT SHOWING REPLACED BATTERIES AND USED RESET BUTTONS
How do I set my sharp atomic clock. Put in new batteries and set time and date on back of clock but the outside temp is not registering?
That makes scence, you have to have an outside temperature probe. If it is wireless it also needs batteries. Check manual for more details.
Nov 07, 2014 | Sharp Atomic Dual Alarm Clock Spc315...
Not showing outside temp, just shows 2 black lines
Is this at the thermostat? Have you replaced any batteries in it? If it is powered from the HVAC units, then is there a fuse blown for the power supply to the thermostat? You depending on where the HVAC units are located, you may need to vist the attic or crawlspace to check this out.
Nov 04, 2014 | Heating & Cooling
I have model 9630 The Weather Channel. I was not receiving the outside temp so I replaced the batteries in both units. After several trys it's still not working. The receiver shows OF.L for the inside
  • Remove batteries from both units
  • Install batteries in outside unit and allow time for it to begin transmitting date
  • Install batteries in inside unit. You should see outside temperature displayed. If not, the outside unit may be defective.
Oct 31, 2017 | Measuring Tools & Sensors
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
I have a TX6470 and cannot receive the outside temp on the inside unit
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed. If there are reset buttons, also try them.
Oct 16, 2010 | Timex TX6490 Wireless Thermometer with...
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Oct 10, 2010 | Acu-Rite Acurite Wireless Weather...
Skyscan digital wall clock just quit showing outside temperature
you probably need to 'pair' the outdoor sensor with the main base: look for a 'channel' button, as these units usually can get information from several sensors and differentiate them by a channel number.
May 10, 2010 | SkyScan 86742 Digital Atomic Wall Clock
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
Acu-Rite AcuRite IndoorOutdoor Wireless Thermometer with Two Receivers Logo
24 people viewed this question
Top Acu-Rite Measuring Tools & Sensors Experts
windryder
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
