Question about Garden
Location of ambient temp sensor
Will it cause the unit to not come on at all whin I try to over ride the accumulated the clutch won't come. On at all
  • 51 Answers
A possible short, or improper connections.
Posted on Nov 18, 2013
I have mits triton nov 2009 4x4 the ambient p0072 makes the eng light come on but it does not have that sensor so I need to know if any knows the colour so I can check wiring thanks
code p 0072 refers to outside air temp sensor ( ambient temp sensor--low input===causes ---wiring short to ground, outside air temp sensor ---ECM
thee has to be an ambient temp sensor as that reports the temp to the ECM to adjust the air/fuel settings for cold starts
it could be in the MAF/VAF sensor area
Apr 29, 2017 | Cars & Trucks
Ac blows hot air
the ac clutch itself is bad there is a little washer in behind clutch sticking easier and almost as cheap to replace compressor
Aug 02, 2012 | Air Conditioning and Heat for GMC G2500
Ambient sensor gauge stopped working correctly at the same time the AC quit
The ambient temp sensor is related to the AC function, if the HVAC system thinks the outside temp is too low, the AC will not be turned on. You probably have a defective temp. sensor. It is easy to change and relatively inexpensive. It is located on the underside of the top radiator support almost in the center (just to the drivers side of center).
The car dying at a stop light can probably be solved by cleaning the throttle body. Make sure that both the front and rear sides of the throttle body are cleaned. And also disconnect the battery during the cleaning process, this will reset the computer and allow it to relearn to the cleaned throttle body.
The compass issue is another separate issue and may just require a recalibration. I don't know what the procedure is but try Googling the subject.
Jul 25, 2012 | 2004 Chevrolet TrailBlazer
Ambient temp sensor replacement
The ambient air temp sensor is located on the radiator support bracket at the top (see figure below, item 1)
Jul 07, 2012 | 2004 GMC Envoy
Where is the ambient temperature sensor located on the 1999 grand cherokee laredo
ambient temperature sensor located behind front grille mounted to bracket on the radiator.
Feb 28, 2012 | 1999 Jeep Grand Cherokee
Air conditioner will not come on. The tempeture gage is reading -40. The sensor is not reading properly.
Hi ruswashingto,
The air conditioner may not work properly if your ambient temp is reading -40. The a/c control unit monitors ambient temp so that it does not operate at too low outside temps. I would recommend fixing the ambient temp sensor and rechecking your a/c operation.
Aug 22, 2011 | 2008 BMW 528i Sedan
2006 jetta tdi, ambient temperature location? my a/c quit working and i have no power at the compressor plug, it is up on charge, the dash temperature sensor quit working this winter, this not reading...
the sensor should be located behind the front bumper grill.look through the bumper grill and you should see the ambient temp sender.on the dash,does the display where the temperature used to read have 3 dash lines?if so there is an open circuit in the wiring to the sensor.this will cause the aircon not to work..good luck.
May 17, 2010 | 2001 Volkswagen Jetta TDI
Where is ambient temp. sensor located?
LOOK ON DASHBOARD AREA FOR A LITTLE BUBBLE LOOKING THING PROTUDING UP SOMETIMES NEAR WINDSHEILD
Mar 15, 2010 | 2005 Dodge Grand Caravan
Where is the ambient temp sensor located on a 2001 S40 Volvo?
Go to Matthew's Volvo Site and search under "ambient temp sensor" I posted detailed instructions and pictures of how to fix this. Enjoy
Apr 16, 2009 | 2001 Volvo S40
Garden Logo
18 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
