Question about Vehicle Parts & Accessories
How to deal with abnormal sound of the engine compartment?
In recent days morning drive, found the car engine abnormal sound, the sound is the kind of dry grinding sound,how to do?
    New Friend:
  • 21 Answers
This could be because the generator belt too tight or water pump pulley or the bearing lubrication generator pulley side, plus the cold start when the pressure is too large, which issued abnormal sound. There may be due to the belt slip slightly, abnormal sound caused. The engine if the idle speed is low,coupled with the engine machine claw installation position is improper, also in the engine jitter, friction machine claw and support on the body will lead to abnormal sound.
find some useful car diagnostic tool to Test out the problem.
Posted on Nov 17, 2013
I need a fuse box diagram for a 1995 Ford Explorer. The fuel pump is not working.
Are u sure it's fuse related , did u get into minor accident recently , there's a fuel pp shut off under passenger side kick panel , I've gotten lucky and this reset button saved me
Apr 12, 2015 | 1995 Ford Explorer
The noise of the engine big, the engine compartment has vibration
Lift the vehicle engine, can see the bottom plate Kepeng traces. If the roadwith obstacles and forced through the bottom plate, the engine must beknocking. The bottom plate deformation and engine oil bottom shell distance, if the distance is too near, when accelerating oil bottom shell and bottom platecollision sends out noise and vibration. So, traffic must carefully observe the road, do not cause drag bottom phenomenon. remove thebottom plate, flat correction can be.Use obd2 for automotive diagnostics , you can improve vehicle safety performance and driving more safer.
Dec 09, 2013 | Ford Cars & Trucks
My isuzy truck mixes diesel and engine oil. what could be the cause?
We dont have these in USA but sounds like an injector is leaking and dripping down past rings or injector pump on some are attached to engine and could be leaking back into the engine block. sorry i can't help you any more than that.
Jun 09, 2012 | Cars & Trucks
I have camry le 2002 recently i notice every morning when the engine is cold i have slow shifting. when put to drive it takes effort by accerelating for 4 mins b4 it picks up and drive normal after about 3...
Sounds much like ****** pump/Tork converter leak down, have you checked the ****** fluid level and condition? better have it checked before you get stuck in traffic.
Aug 29, 2011 | 1989 Ford Bronco
Coolant leaking vw Passat 1.6 1999 heat on with fan, window fogs.
is the floor board on passenger side wet???If yes it's the heater core, which should be accessible by removing the glove box. Did u check the oil, to see if it 's milky??? some times on the vw of any kind, they spring a slow leak on the head gasket which could cause the abnormal starting in the morning. Which then, as the engine warms up causes the gasket to swell up and seal itself untill the engine cools completely off again. Eventually the gasket will completely fail and u'll have to bring it to a shop or get a repair manual to replace the head gasket.
Feb 25, 2009 | 1999 Volkswagen Passat
Break failiure
Well sounds to me like you might have some moisture in the fluid which can cause the breaks to fail. Have your break system flushed totally out and refilled. Brake fluid is very touchy. If you leave brand new brake fluid bottle open for a few days it will draw moisture from the air and ruin the fluid.
Jan 03, 2009 | 2002 Volkswagen Passat
Vehicle Parts & Accessories Logo
62 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
