Contributor
- Posted on Jun 03, 2009
Re: 91 4x4 starts wont sta running more than a few...
Make sure your tubes going to the air cleaner assembly are tight and not sucking air that flap has to be recognised that it is hooked up or it will run off the cold start injector then shut off
91 toyota 4x4 starts but wont stay running more than afew seconds
petro and starts right now
1989 Escort 1.9L Ho Starts rough then idles good for a few seconds then goes back to rough then dies. Then its hard to get started again. No color smoke coming out tailpipe when it is idling. New fuel pump, plugs, wires, rotor,tfi module was checked its good., new fuel injectors. Just cant find the problem please help
it is either running out of fuel after it starts or the ignition key isnt keeping power to the ignition or an imobilizer problem ( if it has one)
is the problem fixed?
if not does it continur running if you back the key of from starting but not tnough to return to normal position (sort of half way)
petrol or diesel?
does it start easy when it starts?
