Question about Maytag Neptune MCE8000AY Electric Dryer
My maytag Neptune electric dryer has no heat in the top dryer but the lower dryer works great
Krazytech
  • 725 Answers
SOURCE: maytag neptune dryer.
check ingitor see it it glows red hot then check flames sensor and or gas solenoids
Posted on Aug 26, 2007
Illeagle
  • 525 Answers
SOURCE: maytag neptune electric dryer
Warning! Disconnect power before servicing!
1.Open the door and remove the screws holding the door, then pull outward on the door to disengage the hinges.
2, Remove the screws on the opposite side of the door opening.
3. Pull outward on the lower part of the front panel to disengage from the top.
4. Remove the screw from the top left and right corner top retainer bracket.
5. Rotate the retainer brackets toward each other to disengage the top from the side panels.
6. Lift top.
Posted on Jun 03, 2008
Illeagle
  • 525 Answers
SOURCE: maytag neptune (gas dryer) just stopped heating
Gas dryers utilize a gas valve, ignitor assembly, and a series of coils mounted on the gas valve to provide heat and safety. The gas valve coils are the usual suspect when it comes to a "No Heat" complaint. I have provided a checklist from www.repairclinic.com, for your convenience. They also provide disassembnly diagrams and repair parts.
Firstly, ascertain that you have made an adequate "Heat" selection, then read on:
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 08, 2009
canbruce75
  • 1776 Answers
SOURCE: Electric Maytag Neptune Dryer not heating up.
If the dryer won't heat up, the problem is typically either a blown thermal fuse or a faulty heating element. The thermal fuse is located just inside the back of the dryer on or near the exhaust duct. It is about one inch long. The thermal fuse and heating element can be tested using an ohm meter or multimeter. These components should have continuity. If either does not, that component is faulty. There is no telling if the moving around of the machine caused the problem or if the timing of the problem was coincidental. Sure hope this helps ya and best wishes.
Posted on Jul 24, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Dryer Won't Heat up
these particular dryers have issues with the heat coils,
it probably has a bad element
Posted on Oct 03, 2009
The lower portion of my Neptune Drying Center does not get hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 31, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Model MCE8000AYW, Lower dryer section - no heat,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 14, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Lower dryer has no heat for drying. Upper dryer continues to work with heat. Can it be fixed?
heatman101
Oct 03, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Lower dryer tumbler will not heat up, upper dryer part works fine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 05, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Its a gas neptune with dryer top. It quit heating so I reset it to factory defaults using the technical manual and the heat came back on but only for one cycle, Top heat works fine. Bottom control panel...
heatman101
Jul 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The lower dryer compartment won t heaT
heatman101
Jun 25, 2010 | Maytag Neptune MCE8000AY Electric Dryer
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune running very hot, even on lowest heat setting
your cycling switch or hi-limit switch is defective they are near the heating element inside the dryer
Sep 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Top works fine, bottom no heat, does this unit have seperate heating elements or could it just be the internal fuse
Are you talking about the element you where looking into the element shroud and that is what you saw? If so your element is gone you can buy a complete element at your local parts depot.The element is fused on to the shroud makeing a dead short. Hope i fixya :)
May 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune Model #MDG6800Aww
Hi!! You seem to have a problem with your heating element on the dryer..Also make sure that your breaker going into your dryer is on..Good luck..
Jan 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
60 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
