Bosch logixx 7
Hi - I can't seem to make the machine work. It will work on one drying cycle but everything else nothing! The buttons won't press so can't start/amend programs. Any ideas?
    Champion:
  • 242 Answers
Sounds like a board fault.
Posted on Nov 18, 2013
  • 1294 Answers
SOURCE: Bosch logixx 1600 workshop manual
Look for user manuals at http://www.user-manual-search.com
Posted on Mar 14, 2008
Yozzer6821
  • 116 Answers
SOURCE: Door lock light flashing
More likely the PCB needs replacing - common fault, you could try a new door switch first cost £5 new PCB £65+ but is easy to replace.
Posted on Nov 09, 2008
localwonder
  • 6784 Answers
SOURCE: dE code on WM0642HW TROMM washing machine
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Posted on Jul 12, 2009
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
Macmarkus
  • 2605 Answers
SOURCE: Hi, my front loader washing
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Posted on Dec 22, 2010
Bosch exxcel washing machine
try checking/replacing the inlet water valve. hope this helps
Nov 24, 2013 | Washing Machines
I have a Bosch Logixx 8 1200 When i turn it on it bleeps and f 37 comes on but it is in a warm dry kitchen, the door won't lock, when I hit the temperature button twice the frost light appears ?
this a problem water level switch
Remove the air hose from the water level switch, and blow into the hose,as hard as possible, to clear any debris that may have accumulated in the hose.
Remove the lower panel, and remove the filter from the drain pump and check and clear any debris from the filter and the interior of the pump, and hoses.
Oct 02, 2012 | Bosch Washing Machines
Help, i turned by Bosch Logixx GSL 14424 GB freezer off to defrost and it now won't turn on...
Turn it round and check the electrics for the compressor are dry. You probably flooded them when defrosting and may have shorted something. If it still won't start with everything dried out, call a fridge technician
May 02, 2012 | Freezers
How do I unlock my bosch washer dryer logixx 7/4. the red lock key symbol is on
Model WVH28420GB :
Firstly, follow the instructions for "Emergency Release" on page 13 of the Operating Instructions for this machine.
If, when you switch on the machine and select a washing programme after doing this, the key symbol still appears, press and hold down the 'Timer' button (second from top on the left hand side of the message panel) for a few seconds until the key disappears. Now operate the machine as you normally do.
Dec 04, 2011 | Washing Machines
Hi I have a Bosch Logixx 8 washing machine that
go to the manufactures website and download the user manual giving the model nr eric
Jan 19, 2018 | Bosch Logixx WAS2446 Front Load Washer
Hi How do you remove the child lock on a Bosch Front loading washing machine Logixx 8
Hi
Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Thanks for contacting fixya.com
Nov 13, 2009 | Bosch Washing Machines
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
