Question about Ovens
Candy oven symbol meanings - Ovens
Candy FPP609X oven not heating up
8888 usually means the clock needs setting as it has been disconnected from the mains.
Oct 07, 2017 | Candy Ovens
Meaning of symbols on the oven
Depends what the symbols are.
Jun 08, 2017 | Ovens
CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Feb 22, 2010 | Candy F248P Electric Single Oven
How do a change the element on a candy oven , can't get to the old element
You have to gain access to the element by removing the outer rear panel of oven, if it is built in, then this means removing it from the housing.
Once you have removed the cover, and possibly the top panel, you will see how the element is fitted.
It is a fairly straight forward repair to do.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Candy F248P Electric Single Oven
Volume control candy oven timer
Switch off the oven, leave for 5 seconds and switch it back on.
Candy Customer Services asked for over £100 to have an engineer sent to my house, which I refuse as I thought the oiven was good.
I had to switch off all the electricity in the kitchen but after this 'reset' the oven turned to the normal 'high' volume.
Jan 12, 2010 | Candy Ovens
Candy sprinter hobb all on L locked?
Ours started doing the same Displaying L on four hob displays. I figured to press the bottom right hob and the minus button at the same time should unlock it.
Thanks
Trev
Oct 07, 2009 | Candy Ovens
Omega Europa 20-1 oven. What do the symbols mean?
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
Oct 03, 2009 | Ovens
Candy oven noisy fan
Noisy fan means bushes are worn. cant be repaired. needs replacement. Quote model of oven to spare parts supplier and replace. Make sure power is unplugged and not just switched off before repairs are done.
Sep 14, 2009 | Candy FP855 Electric Single Oven
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
