2002 DODGE DURANGO 5.9L- NO SPARK AND NO FUEL.WHAT WOULD DO THAT
    New Friend:
  • 17 Answers
Maybe a bad oil press. Senser or something simler that gives info to pc.
Posted on Nov 17, 2013
Where is the fuel reset switch on a 2002 Dodge Durango SLT?
Sorry but dodge doesn't use a fuel reset switch . Fuel pump relay , ASD relay - auto shut down . Have no fuel ? Did you do a fuel pressure test with a pressure gauge ? Do you know how to do automotive electrical testing ? Fuel Pump Electrical Circuits Description and Operation
Mar 08, 2017 | 2002 Dodge Durango
02 durango wont start
Is it getting fuel and or spark? If the fuel pump is working and the the plugs are getting fire then perhaps a clogged fuel pump strainer is to blame.
If the fuel is reaching the engine, then test the coil. If no spark is event replace the coil.
Dec 08, 2011 | 2002 Dodge Durango
2002 Dodge durango take long time to start
CHECK..
  • SPARK PLUGS
  • BATTERY CHARGE
  • AIR FILTER
  • FUEL PUMP AND LINE
  • MAINLY THIS SHOWS WHEN CHARGE OF THE BATTERY IS NOT SATISFIED!!
  • PLS VOTE!!
Sep 24, 2011 | 2002 Dodge Durango
Code p0300
Hello
Here is a list of what i have found with your problom
Let me know if you need assistance in checking anything out
  1. Spark plugs
  2. Spark plug wires
  3. Ignition coil
  4. Fuel injector
  5. Wiring to fuel injector
  6. Timing Belt
  7. Vacuum leak or stuck open EGR
  8. Contaminated fuel or bad fuel pump
  9. Weak compression
  10. Blown head gasket
Jul 14, 2010 | 2001 Dodge Durango
I have a 2002 Dodge Durango. Over the last year,
Test fuel pump for proper pressure.Replace fuel filter.Check all spark plugs and spark plug wires for wear or deterioration.Have idle checked.Check all electrical connections.Check for vacuum leaks.
Mar 19, 2010 | 2002 Dodge Durango
I have a 99 Dodge Durango 5.9 that is not getting spark or fuel
The control module in the distributor that signals the coil to fire also signals the fuel pump to operate replace should cost around $50
Oct 11, 2009 | 1999 Dodge Durango
Dodge durango
Check to see if you are getting fuel pressure. If you can not hear the fuel pump run with the key in the on position then it is bad. If you are getting the right fuel pressure then you should check the spark
Apr 29, 2009 | 2002 Dodge Durango
2002 Dodge Durango won't start?
fuel pump is working?and how about spark ign coil? I recommend investing in spark tester! also sit in side windows up nice and quite turn key all the way do not crank it! do you hear grrrrrr that would be your fuel pump no grunt no pump if so!! I would consider looking into no spark if I were you good places to start!
Jan 18, 2009 | 2002 Dodge Durango
2004 DODGE DURANGO, 5,9L ENGINE
the message is appearing because a sensor in the transmission, usually in the transmission fluid, detects higher than normal temperatures which is usually a result of increased friction which isnt good. I would get the sensor checked before you get the transmission worked on.
Oct 07, 2008 | 2004 Dodge Durango
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
