Question about GE Audio Players & Recorders
Can display be brighter
GE model 7-4835B
Adjust display brightness on frigidaire PLMV168
Good Afternoon Friend,
I understand that the display on your Frigidaire microwave, model# PLMV168, is dim and you are wondering if there is a way to make it brighter. There is not a way to make the display on your microwave brighter. That is the particular design of your appliance. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire PLMV168 Microwave Oven
Uneven backlight
Your set is probable defective
Sep 21, 2017 | Sansui Televison & Video
The control display on my microwave is very dim. Is there any way to make it brighter?
If you had mentioned your full model number, we could have looked whether the VFD is available as a separate part in case your model has a VFD display, or whether the whole control board would have to be replaced.
If your model has an LCD type display, it may be weak LEDs or other failing components in the display backlight circuit.
We regularly repair microwave displays for $39.95 nationwide.
It's pretty rare for a microwave to have a display brightness feature.
Let us know if we can help you further.
Nov 16, 2012 | Whirlpool MH2155XP Microwave Oven
I have a CDA 7892 alpine works great but would like the display to be brighter seems a bit dim manual does not say this model can be adjusted or am i missing it any help thanks in advance
You didn't specify if you wanted the display brighter in the daytime while headlights are off or if it is too dim when the headlights are on, with respect to the rest of the instrument panel illumination. Too bright is easier to deal with but too dim is tough. If it is always too dim under but daytime and night time conditions the only way to improve brightness would be to very gently disassemble the front panel (easier if it is the removable type) and determine what provides the back lighting. If there are tiny LEDS you could painstakingly add more LEDS or swap them out for brighter LEDS. There could be a lot of guesswork determining if this or that LED was brighter than what is in the unit as built. It may just be easier to live with it as-is.
Mar 26, 2011 | Alpine CDA-7892 CD Player
The brightness of the display panel on the GE XL1800 is so dull I cannot even read it. How do you increase brightness?
There are two main causes for this:
- Dust & other particle buildup on the front of the display gass and the rear of the display window. This can be cleaned.
- Your vacuum display tube is wearing out and the control circuti board must be replaced.
Cleaning the display is easy, but you need to be careful so you don't break the glass.
First you would unplug the microwave or turn off its breaker.
Then see the video here that shows you how to remove your control panel assembly in less than 5 minutes.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the plastic frame.
Then carefully (since the display is made of glass) remove your circuit board.
Using a soft cloth (since paper towels can scratch) lightly dampened with non-ammonia cleaner (since ammonia can damage some polycarbonate plastics), gently wipe off the front of the glass.
Then gently wipe off the back side of the plastic display window in the plastic control panel frame.
Reassemble, reinstall, and power it up, and it should be brighter, sometimes a whole lot brighter!
If that does not brighten it up enough, then you will need to replace the entire circuit board, since the display tube on this brand is not available as a separate part.
You can use the disassembly instructions above, and the board can be ordered by entering the full model number from the tag in or on your unit here.
For those with other brands, or whose model does not show up there, see this page for tips to finding helpful exploded views and ordering appliance parts and accessories.
May 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ipod touch 1st generation display very dark
You probably reduced the brightness one time, but you just forgot about it. To make the display brighter, do this:
>on your iPod touch screen, go to Settings.
>once the Settings window is open, you'll see Brightness from the list, tap on it.
>now, you drag the button to make the display darker or brighter. drag it to the left to make it darker, to the right to make it brighter. You'll notice the display darkens / brightens simultaneously as you drag the button.
For more iPod touch / iPhone tips, click here. Feel free to comment on my tips if you have other questions.
Mar 05, 2010 | Apple iPod touch
GE Arctica Refridgerator, PSS26MSRB SS, water leaking from tray, and other questions
ok first the water dispenser i would take out the drip tray and run a thin bead of black silicone to seal it there as to the turbo light getting brighter its because when you switch on turbo its running more power through the switch to the fan now to the fan early model fans were noisy i think ge redid them and if you contact ge you can get one of the newer fans hope this helps by the way loved the pics and mpeg that helps
Jan 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Dim Digital Display
Connie P, Unfortunately it is not possible to make the display brighter. The only solution is to replace the entire clock/timer. The price for the part is less then a hundred dollars and if you will give me the complete model number and a color, I can help you to find the best deal. Gendos...post back
Jan 06, 2007 | Frigidaire FEF326 Electric Kitchen Range
22 people viewed this question
Top GE Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jonathon summesfield
Carlos L. Burgos
Carlos L. Burgos
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
