Background change color
Want to change the background color of screen
  • 113 Answers
It depends on what operating system you have. In Windows, go to Control Panel, then Personalization, the Background.
Hope this helps!
Posted on Nov 17, 2013
I have a black square on which my twitter profile information sits - how do I change the black background to something else?
If you want to upload your own background image or customize the sidebar and color scheme of your page, follow the steps below.
  1. Sign in to your account.
  2. Go to your Settings and click on the Design tab.
  3. Scroll down to the Customize your own section.
  4. Click on Choose file to upload a background image. images justify to the top left of the screen. You cannot stretch your image to fit. It will display as the size you uploaded (file must be smaller than 2MB).
  5. Check the box to Tile background if you want your picture to repeat across the background.
  6. Choose whether your Background position will be left, center or right.
  7. If your image isn't very large, choose the background color that will show behind the image.
  8. Choose a color for links.
  9. Choose a black or white transparent overlay.
  10. Click Save changes.
Source: Customizing your profile design
Jan 09, 2014 | Computers & Internet
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Right click the desktop and click "Personalize" - color scheme dialog should be in there.
Jan 01, 2014 | Computers & Internet
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Oct 03, 2012 | Microsoft Windows XP Home Edition for PC
How do i change the screen size -resolution on my computer?
Windows 7 Starter edition comes with one desktop background, which can't be changed or customized. Please see this link for details.
http://windows.microsoft.com/en-US/windows7/Personalize-your-computer
To change the desktop background
  1. Open Desktop Background by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_47.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Desktop Background.
  2. Click the picture or color you want for your desktop background.
    If the picture you want to use is not in the list of desktop background pictures, click the Picture location down arrow to view other categories, or click Browse to search for the picture on your computer. When you find the picture you want, double-click it. It will become your desktop background and appear in the list of desktop backgrounds.
    8456a207-d4c8-401d-8729-c5dda3f0e72c_15.pngLook for pictures in other locations on your computer
  3. Under How should the picture be positioned, choose to have the picture fit the screen, tile, or be centered on the screen, and then click OK.
gl_ico.pngNote
If you choose to have a centered picture as your desktop background, you can also have a color background to frame your picture. Under How should the picture be positioned, click Change background color, click a color, and then click OK.
Feb 10, 2012 | E-Machines eMachines Desktop PC
I have an Acer windows 7 laptop. bt it seems that the wall paper cannot change. i dont know if I cant change it or it cannot be changed. please help. what should I do?
  1. Open Desktop Background by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg and clicking Control Panel. In the search box, type desktop background, and then click Change desktop background.
  2. Click the picture or color that you want to use for your desktop background.
    If the picture you want to use isn't in the list of desktop background pictures, click an item in the Picture location list to see other categories, or click Browse to search for the picture on your computer. When you find the picture that you want, double-click it. It will become your desktop background.
    8456a207-d4c8-401d-8729-c5dda3f0e72c_65.jpgLook for pictures in other locations on your computer
  3. Under Picture position, click the arrow and choose whether to crop the picture to fill the screen, fit the picture to the screen, stretch the picture to fit the screen, tile the picture, or center the picture on the screen, and then click Save changes.
gl_ico.png Note
If you choose to have a fitted or centered picture as your desktop background, you can also frame your picture with a color background. Under Picture position, click Fit or Center. Click Change background color, click a color, and then click OK.
gl_ico.png Tip
To make any picture stored on your computer (or a picture you are currently viewing) your desktop background, right-click the picture, and then click Set as Desktop Background.
7abb27d7-2989-4144-81e3-0a51f703885d_50.jpgThe Set as Desktop Background option
You can add more desktop backgrounds to your collection from the Personalization Gallery on the Windows website.
Aug 31, 2011 | Acer Computers & Internet
How do i set laptop background image on my compaq 615?
This can be found in the Help and Support section of Windows on your laptop.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconRight click on your desktop-Select personalize. This will open a window that asks you to select your desktop background
    getcontent.aspx?assetid=8456a207-d4c8-401d-8729-c5dda3f0e72c&documentset=en-us&prod=win700&market=usLook for pictures in other locations on your computer
Note
  • If you choose to have a fitted or centered picture as your desktop background, you can also frame your picture with a color background. Under Picture position, click Fit or Center. Click Change background color, click a color, and then click OK.
Tip
  • To make any picture stored on your computer (or a picture you are currently viewing) your desktop background, right-click the picture, and then click Set as Desktop Background.
getcontent.aspx?assetid=7abb27d7-2989-4144-81e3-0a51f703885d&documentset=en-us&prod=win700&market=usThe Set as Desktop Background option
Apr 24, 2011 | Computers & Internet
The screen background color
This is night view. Go to page 34 of the manual and select Customize section Set your Nuvi to auto from TOUCH TOOLS SETTINGS
Aug 21, 2009 | Garmin nuvi 255W GPS Receiver
Hi how do i put a backround on my phone
Hello edgar_25_06,
Putting a background on the palm centro phone could either mean adding a background picture or changing the background color. If changing the color is is desired then its simple:
•Select the the 'System' category in the drop down menu at the top of the main screen.
•Open the Prefs application.
•Select 'Color theme' (near the bottom of the Prefs options).
The Color theme option displays a list of many different screen color settings. Each one of the color themes can be selected and tested on the centro until you find the one you like. Adding a picture for a background is a different matter. I haven't found out how to do that yet.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw562
Jul 18, 2009 | Palm Treo 500 Centro
Computers & Internet Logo
David Payne
David Payne
