Maytag 3000 My Maytag front load washer just stopped working, it acts like the cycle is running, water pours in but the drum does not turn so everything just sits there.
    Top Expert:
  • Computers & ... Master
  • 25,695 Answers
Does the drum turn? If not check the fan belt, motor then motor controller.
Posted on Nov 17, 2013
Fills with water between washes
try extending your drain hose up alittle higher
Sep 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
When empty, I can turn inside and sounds like there is water sloshing inside
This is not a problem actually. That is quite normal for top load washers. What happens is when the pump comes on to expel the used water it only runs long enough to empty the inner drum. The outer drum still has a little bit of water inside to act as a pea trap of sorts. This keeps undesirable smells from reentering your pipes and causing bad Oder's in your home. As long as your cloths come out clean and partially dried from the spin cycle then your washer is working correctly. Hope this helps. Good luck.
Mar 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sits Pretty Doing Nothing,ARG!
Any codes on the front?. Try here to see if it's any help: Type in MAV6000 only
http://servicematters.com/maytag_library/html/index.html
Danwan
Sep 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Machine dosent seem to drain model #lat8840b maytag
my machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
Aug 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune out of balance on spin cycle
Hi, try to check the spring virator support might pollout from slot or hole connected, some adpter are rusted spring replace it are also available in appliances store.
Feb 15, 2008 | Washing Machines
Computers & Internet Logo
David Payne
David Payne
