Question about Stoves Premier 900GRa Gas Double Oven
Grill ignition Hi, when I ignite the grill in the top oven of my stoves 900 it operates normally for approx 2 min. However, after 2 min the ignite-er starts to spark intermittently. I have replaced both rotary switches and the top oven rotary switch for the second time, thinking it was a faulty switch, still to no avail. Once ignited, gas appears to be a nice even flow, and no obvious shorting/chaffing of cable or loose connections.Many Thanks Robert
3 Suggested Answers
SOURCE: hi i cant seem to get my grill or oven on can any one help
thanx for the site guys i got the no for the co and they going to get back to me thanks again
Posted on Dec 30, 2008
SOURCE: Stoves 720 / 900 GRa GR DO gas electric dual fuel oven
Our oven had the same fault.
It turns out that the air intake was blocked.
The air intake is at the front, just below the bottom oven door. Some liberal sucking with a hoover sorted the problem instantly.
Posted on Apr 15, 2009
How do I turn my oven on? I have never had a gas stove, but I cant get the stove to start except if I turn right to grill in other words I can get it to ignite for 180 degrees etc only grill
normal operation is to push the oven knob in and turn
pushing in sets the igniter off and turning opens the gas flow to ignite
always light an oven with the oven door open
stop s an explosion if there is a problem
down load an operators manual bu going google and typing in --- user manual for ( make and model ) gas stove --- find a pdf version and download it
Aug 13, 2016 | Ovens
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
Hello, We have a Kenmore gas stove model # 71761. The burners on top work good.The issue is with the oven portion. Oven is working. Flame comes on upon ignition to desired temperature setting and then...
It sounds like yous stove is working fine. Cycles fine. If you think the stove is cycling more often than when new then ck the seal on the door. You may be loosing heat.
Jan 14, 2011 | Ovens
I have a Stoves double oven and after a power cut the clock has stopped working and the main oven is not working either. the clock is completely off. the small top oven is still working though. what can...
The clock controls the ovens. In other words, directly you set any time on the clock, a contact operates within it to provide power to the ovens. (Normally the grill remains operational). You may need a new clock/timer. Before you do so, try switching the power off at the main isolating switch and leaving it off for a few mins, then switching it back on, to try to get the clock to operate. You may need to do this a few times.
Normally Stoves stick a label identifying the model on the left hand edge of the lower oven. You see this when you lower the main oven door. it will probably start with a 05 and be 9 digits long. With this number you can identify the oven and obtain parts.
Nov 07, 2010 | Stoves 720EF Electric Double Oven
I have had 3 engineers out to try and fix my stoves 720gra cooker and has changed all the printed circuit boards ,and all other parts but still the top oven and grill doesnt work and has now been classed...
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
Oct 01, 2009 | Stoves Premier 720GRa Gas Double Oven
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Hi i cant seem to get my grill or oven on can any one help
Dec 28, 2008 | Stoves Premier 720GRa Gas Double Oven
Wolf oven - oven clicks continuously
This sounds like you have a flame switch getting ready to go out. The reason you are hearing the ticking noise is that after the ignition is satisfied the flame switch is not detecting and sending a signal to continue to try for ignition.
Nov 02, 2008 | Ovens
Apr 06, 2008 | Stoves Premier 720GRa Gas Double Oven
Stoves Premier 900GRa Gas Double Oven Logo
Top Stoves Ovens Experts
John Tripp
John Tripp
Oloyede Monsuru
Are you a Stoves Oven Expert? Answer questions, earn points and help others
