Panasonic sa xr70 error f76
Error code f76
5 Suggested Answers
poging
  • 14 Answers
SOURCE: Panasonic home theatre model SA HT640 with error
check fan on the power modele ic it might not be rotating
Posted on Mar 06, 2009
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
ravichetty
  • 158 Answers
SOURCE: fault code for sa ht 17
Hi,F76 is the error displayed when the fan goes faulty in the unit.
Posted on Aug 19, 2009
  • 1054 Answers
SOURCE: sa-100bt i have an f76 error after taking unit apart i have found that there is a black wire next to where the fan plugs in this wire has been disconected does any one know where it goes thanks
Usually that is just to wrap around the fan cable to make sure it doesn't go into the fan. F76 error can be either the fan is not turning, or the amp is bad.
Posted on Apr 16, 2013
I have a panasonic SC PT960 system. Haven't used in months. Turned on,got error code F76. Tried unplugging and plugging back in to reset, but it did not work. What is wrong with my system?
"F76" is a power supply problem. Could be something really simple or something much harder to figure out. These units aren't really user serviceable and it's way too old to still be in warranty(?) so maybe you've been whapped with a subtle hint to upgrade to a blu-ray HT system. You'd be able to keep the rest of the system and just replace the head unit.
Jan 02, 2017 | Panasonic Audio Players & Recorders
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
Dec 27, 2014 | Panasonic Sa-pt770 Receiver
Sa-100bt i have an f76 error after taking unit apart i have found that there is a black wire next to where the fan plugs in this wire has been disconected does any one know where it goes thanks
Apr 16, 2013 | Panasonic sa-ht930 Home Theater Audio...
I have an old Panasonic SA-HT40 surround sound system. When the unit is powered on the error message "F76" shows on the display and then the unit shuts off immediately. The user manual instructs to un
I have the same problem with my Panasonic model SAHT-40. I get the same code plus popping and shortly reads maximum overload then cuts off. I disassembled my unit and discovered that my fan fails 2 work causing the unit it over heat. I called Panasonic 2 place an order 4 a cooling fan. This model is obsolete they dont even manufacture parts 4 this unit anymore. The closest that I can get with my credit card is Samsung model AH31-00056B cooling fan through Panasonic. I hope that this solution helps all of u out with ur unit!
Nov 30, 2012 | Panasonic SC-HT40 System
Fault code for sa ht 17
Aug 11, 2009 | Panasonic SC-HT17 System
My panasonic SA-AK57 it is displaying error code F61
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SC-EN17. F76
you wil have to subtitute a tech for a dealer instead.they will be able to help check along the left side of the home page for fixya and try to locate a repairman near you just put in your area code.good luck.
Apr 06, 2007 | Panasonic SC-EN17 CD Shelf System
Error Code "F76"
spoke to a friend at an authorized servicer and he said he has never heard of that code but from what yourm describing its eather the outputs the speakers or the power supply Oh and a sevice manual is availiable at the partstore.com or from the panasonic web site as I've been there. good luck
Apr 10, 2006 | Panasonic SC-PM08 Shelf System
50 people viewed this question
 Grubhead
Grubhead
