Question about Canon FAXPHONE L170 Plain Paper Laser
Dark copy paper - Canon FAXPHONE L170 Plain Paper Laser
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Tip
Troubleshooting MINOLTA DI 1611, DI 2011
The copy is too light. The copy density is set too
light.
Use the Auto/Photo
key to select a darker
copy density .
The copy paper is damp. Replace the paper.
The copy is too dark. The copy density is set too
dark.
Use the Auto/Photo
key to select a lighter
copy density .
The document was not
pressed close enough
against the Original Glass.
Position the document so
that it is pressed closely
The copy is blurry. The copy paper is damp. Replace the paper.
There are streaks through the
copy.
There are specks throughout
the entire copy.
The Original Glass is dirty. Wipe the glass with a soft
dry cloth.
The document pad is dirty. Clean the document pad
with a soft cloth dampened
with a mild detergent.
The original is highly
translucent, such as diazo
photosensitive paper or
OHP transparencies.
Place a blank sheet of
paper over the document.
A double-sided document is
being copied.
If a thin double-sided
document is being copied,
the information on the back
side may be reproduced in
the copy. Use the Auto/
Photo key to select a
lighter density for the
background.
The Imaging Unit has
reached the end of its
service life.
Contact your service
representative.
on Dec 18, 2009 | Office Equipment & Supplies
Makes dark line on paper
if you are using your doc feeder check and see if there is anything on the small glass the one that is about an inch wide other then that could b fusing or drum issue
Jun 21, 2009 | Konica Minolta DiALTA Di200 Copier
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Want a B&W copy from colored sheet of paper w/o dark background.
It's never going to be perfect (unless the background is quite light in colour), because the copier basically "sees" the coloured background as "gray", and the darker the background the more "gray" it looks. Try setting the original type to "photo" mode, and then adjusting the exposure a little lighter/darker....that's all you can basically do.
Mar 25, 2009 | Canon imageRUNNER C5180 Color Copier
Dark papers
are you using brother products or generic. using some generic supplies will cause this problem
Jan 14, 2009 | Brother FAX-8070P Plain Paper Laser
Dark lines on edges of copies
make a copy when you here the paper getting picked up count 2 seconds and open front cover or side stopping the process open the copier and see if the dark line is on your drum or transfer is the problem
Nov 23, 2008 | Sharp AL-1642CS Copier
Canon NP7161copier ( Indicates 8z and stops copying)
Dark shades on both side of the paper? Drum cleaning blade or fuser assembly. Check the upper fuser roller and the drum for build up.
Jul 16, 2007 | Canon NP 6551 Black and White Copier
Canon FAXPHONE L170 Plain Paper Laser Logo
19 people viewed this question
old marine
old marine
