Question about Furniture
Euro grand bar fridge glass front. Have just replaced curcuit as supplied as apparently all had 100 % failure rate! We bought 3 including dual zone wine fridge. Have replaced boatds, but not not cooling f1 error n e? Error when trying to reduce temp. On wine fridge, cant swap between sparkling, white, red. When pressing lhs buttons rhs numbers change?? Help
  • 27 Answers
If these were bought new, it sounds to me like the company still has a problem with their control boards. I would get the manufacturer on the phone and ask to talk to someone in Engineering.
If bought used, be sure they are set up for the proper supply voltage.
Posted on Nov 17, 2013
SOURCE: THE UNIT DOES NOT COOL ANDY COLDER THAN ROOM TEMPERATURE.
does the compressor run ? if so you could have a low refrigerant charge, a sealed unit resrtiction, leak or defective compressor.
Posted on Apr 30, 2010
mrbobfixit
  • 259 Answers
SOURCE: Are red wines stored on the top or bottom of the
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Posted on Jun 14, 2010
SOURCE: Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
Posted on Aug 16, 2010
SOURCE: Both zones of the wine
Check the thermostat for temperature setting. Also check the condenser coils and clean them if found clogged with dust. Unplug the wine cooler and wait for a couple of hours before plugging it again. If you can hear it running or whining, perhaps the compressor is being overheated. Test various components such as temperature control knob, evaporator fan, defrost timer, compressor relay, overload protector and the compressor motor.
Take care.
Posted on Oct 22, 2010
  • 239 Answers
SOURCE: received apparent error message "E3" for upper
E3 is a fan error. This is usually caused by poor connection to the fan. Remove all connectors and reinstall assuring tight connection. This should remedy it unless the fan is bad, which is very rare!
Posted on Jan 13, 2011
I want replace compressor. Compressor number ND52LABM
to replace the compressor you will need specialist equipment including an oxy set, pressure gauges and a bottle of refrigerant
the cost of replacing the compressor make a new fridge very attractive , as you will be told by fridge mechanics
just be very sure because a lot of apparent compressor problems are attributed to the start /run capacitor failure
I recommend a talk with a fridge mechanic to be sure before you open the system
Aug 13, 2015 | Refrigerators
Tip
Specifications of Apple iPhone 7 LCD Screen
Compatible with: Apple iPhone 7
For Apple iPhone 7 LCD Screen and Digitizer Assembly with Frame Replacement - Black
This item includes the following parts:
1. LCD Screen;
2. Digitizer Touch Screen;
3. Front Frame;
Note: Please test the functionality before installation.
Specifications:
Screen Size: 4. 7 inches
Resolution: 750 x 1334 pixels (~326 ppi pixel density)
Display Type: LED-backlit IPS LCD, capacitive touchscreen, 16M colors
Protection: Ion-strengthened glass, oleophobic coating
Type of Connector: Buckle
Features:
• This iPhone 7 Screen Replacement includes the components as mentioned above, it does not include the small parts.
• The Apple iPhone 7 LCD screen and digitizer assembly with frame replacement is original and brand new.
• The Apple iPhone 7 screen replacement is available in Black.
• This iPhone 7 LCD Assembly is 100% brand new and original, and each product of Rootmi Goes through strictly inspection before shipping out.
• This LCD screen and digitizer assembly with frame replacement is compatible with iPhone 7 only. Please do not confuse it with other version. For Apple iPhone 7 LCD Screen and Digitizer Assembly with Frame...
on Apr 06, 2017 | Electrical Supplies
How d I swith passenger side mirror on a power mirror on a 2004 Jeep Grand Cherokee limited edition
no symptoms posted (broke glass or ???) can we be on same page?
"how do I switch," verb switch , the mirror as switches inside, too.
please say what that word means. switch and the failure.
1: remove and replace with new.
2: move right to left and left to right side.
why would you do that #2
fold away mirrors/ Export only (this is usa forum so..)
these,NASA grade mirrors are very complex... not just glass and plastic. heaters ,motors, memory , etc.
the FSM cover all tests for the mirror, including scan data.
ill quote the FSM now , 8 steps (just 1 fail,not heat, not memory failure or fold failure)
ONE MIRROR INOPERATIVE
(1) If the one inoperative mirror is on the passenger
side, go to Step 2. If the one inoperative mirror is
on the driver side, go to Step 3.
(2) Check if the passenger front door will lock and
unlock using the power lock switch on the driver side
front door. If OK, go to Step 3. If not OK, go to Step 6.
(3) Disconnect and isolate the battery negative
cable. Remove the trim panel from the front door.
Disconnect the 12-way mirror wire harness connector
from the door wire harness connector.
(4) Using two jumper wires, test the mirror as
shown in the Mirror Test chart (Fig. 2). If the mirror
tests OK, go to Step 5. If the mirror does not test
OK, replace the faulty mirror.
(5) Disconnect the 12-way door wire harness connector
from the door module connector receptacle.
Check all of the circuits of the door wire harness
between the connector for the mirror and the connector
for the door module for opens or shorts. If all of
the circuits are OK, replace the faulty door module.
If any of the circuits are not OK, repair the open or
shorted circuit(s) as required.
(6) Use a DRB scan tool and the proper Diagnostic
Procedures manual to test and repair the faulty Programmable
Communications Interface (PCI) data bus
communication between the two door modules.
(bar stool answer) all cars. mostly
pull door skins
unplug motor conn.
unscrew mirror base from door.
extract mirror,
Mar 07, 2015 | 2004 Jeep Grand Cherokee
Error code E9 on euro grand bar fridge
I have the same problem, anyone knows what E9 means?
Jan 23, 2014 | Refrigerators
Egr code what does it mean
if its the 3.3 then the code would be--0406 egr sensor A curcuit high--- the common fix is to change the egr valve assembly which includes the egr transducer. This egr valve has also a high failure rate and you can check this out by calling the Dodge parts dealer. good-luck !! once egr valve is replaced. have light turned off with scanner. because if it stays on, pcm thinks it still has the problem. it will not send right info to pcm.
Jan 29, 2011 | 2006 Dodge Grand Caravan
Im looking for a curcuit diagram for the switchmode power supply in my Behringer PMP3000.
If the supply failed I can tell you which parts to replace... and if it failed there may be a failure in the power amp that caused it. You can contact be directely at fredy2 @ aol.com... put Behringer in the subject.
The supply when it fails takes out eleven components including two expensive IGBT transistors. If the rearmost amp fried, add at least four more components and a lot of work carving out burned board and wiring around the blown circuit traces.
May 30, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
No ice or water from in-door dispenser
When you first hook water up to the refrigerator you have to fill a tank in the fridge. Open the water supply behind the ref. turn the control on the front of the ref to water and hold a glass under the spout as if you are filling a glass . You may have to wait 3-4 minutes forthe tank and lines to fill with water before you get any to come out into the glass. The water my be discolored at first so run a few glass full through before drinking . hope this helps
Bobalix
Apr 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge won't run
hi brenda,
can u hear a humming sound as if it is trying to start then it would stop after a clicking sound?
if it does then it is your compressor trying to start but can not do it.
you could either have a problem in your starting relay of overload protector of the compressor or the compressor itself is the defective part and it needs to be replaced.
i hope i was able to help.
pls rate me
tnx
drcool
Jul 21, 2008 | Magic Chef MCBR440 Compact Refrigerator
Magic chef bar fridge
Have the same problem with my 3 year old bar fridge. I could hear a clicking sound like it was trying to come on. Unplugged it and bought a new one. I figure the cost to repair a $100 bar fridge may not be worth it. They will charge you to come out and then charge you for the parts. For a little over $100 I bought a new one.
On the new fridge, the freezer gets colder than the fridge part..but luckily for me, it is still under warranty (Manufacturer's). I'll call for a look see-who knows maybe that guy can tell me what's wrong with the other one, too. ;-)
Feb 06, 2008 | Magic Chef MCBR440 Compact Refrigerator
Furniture Logo
192 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
