Defy laundromaid electro logic 1100
Machine alarm went off. Refused to continue cycle from Rinse onwards. LE appeared on the digital screen
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: I have a Defy Laundromaid
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the bottom part of the tub and blow on it and test the terminals of the sensor if it will close or open.
Hope helps.
Posted on May 28, 2011
MY MACHINE DOES NOT RINSE OR SPIN, WATER STAYS IN MACHINE. DEFY LAUNDROMAID TOP LOADER MACHINE
It sounds to me that there is a blockage in the pump or assosiated plumbing or the pump itself is burnt out or belt has come off. Im not familiar with your paticular machine but they all work on the same principle. only other possibility is if you have a drip dry switch that has been accidently switched on. Good luck.
Aug 16, 2017 | Washing Machines
My defy laundromaid 720 does not stop the waterflow once the drum is full, which leads to water running out the bottom of the machine and then gives me an error LE
problem either in the water level control switch or the solenoid valve that shuts off the water
if the water doesn't shut off but it progresses progress to wash while still filling, it will be the water solenoid valve
Oct 08, 2016 | Washing Machines
I have a defy laundromaid. The machine doesn't reach the correct water level to start the washing cycle. However if I deselect wash and rinse options it does spin
good solid commercial unit 13 kg
could be a timer or control board fault
my best guess is
faulty water level sensor
Sep 20, 2016 | Washing Machines
My Defy Laundromaid Electro Logic 920 is showing and 'EU' error msg. How do I clear this.
disconnect the power cord from outlet box by 45 seconds. Hold the power button in OFF. Connect again and try it.
If this do not resolve the problem, you must call to the company or some tech service for fix it
God bless you
May 28, 2013 | Washing Machines
I have a Defy Laundromaid Electro Logic 1100 washing machine and it is now giving me an E9 error. What could be the problem?
Hope helps.
May 28, 2011 | Washing Machines
Defy Laundromaid 1300 has a serious leak. I've checked the filter, and there is nothing in it to cause it to leak. We had a Defy techinician come out and he also cannot find the leak. Please advise...
water pump is not functioning properly, when in spin cycle water in drum pushes up and over the top, symptom is water leaking out the bottom which indicates a leak but its actually the water pump not pumping out all the water. Gets air trapped in the pump which results in air lock and no head for the pump to function properly. Fix is to lower your drain pipe to same level as pump when in spin cycle so that the water runs out freely this will not solve the problem but will allow you to continue washing until you have the problem sorted.
Dec 26, 2010 | Washing Machines
I have Defy Laundromaid 1300. I was getting an E9 message.
Hi, I get an OD (wording) on my machine after washing-dosnt rinse or spin... what can that be???
DEFY LANNDROMAID 1300M!!!
Sep 21, 2010 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
