Question about Ariens Riding Lawn Mower. 42 in. 19 HP Kohler Hydrostatic 960460024
I wish to install a manual choke since the automatic choke no longer works
I have to remove the air cleaner cover and spray ether in the carb if it has been sitting turned off for more than 30 minutes. This same issue happened on our previous Ariens lawn tractor so we replaced it within 30 days of purchase. Now this one is doing the same thing. I have found a work-around by drilling a small hole in the air cleaner cover (large enough for the ether spray tube) and then covering with a piece of duct tape but that is not the preferred method. If there is such a manual choke cable that can be installed and someone knows the part number that would be appreciated.
  • Brent
    Brent Nov 18, 2013
    Thanks! I will check for those things that you mentioned before going down the path of installing a manual choke cable. Again, thank you for your guidance.
  • 27 Answers
Brent,
Most any auto parts store will have a manual choke conversion kit for about $10us.You will have to be a little creative to hook it up. But...your engine shouldn't need to be choked once it runs awhile and is still warm. I would look for other causes like binding linkages, unhooked springs and loose carburator mounting.
Posted on Nov 17, 2013
  • Brent
    Brent Nov 18, 2013
    Thanks! I will try those things that you mentioned before going down the path of installing a manual choke cable. Again, thank you for your guidance.
  • 2692 Answers
SOURCE: My Ariens snowblower (model #924048) won't start
Dissamble carburator. Spray Carburator cleaner  through passages, and wash out bowl. Dump gasoilne if old.  Reassemble Carburator. PS count the turns on the two Jet (mixing) screws and place back into the same position after cleaning passages.
Posted on Dec 27, 2008
trippssmengi
  • 76 Answers
SOURCE: Ariens snowblower ST724 leaks gas from the carbourater
The little metal peice with the wire ataches to the float at the hinge part of the float, if you use yahoo type in tecumseh carburetor diagram then click on Parts and Diagrams and the web address is partstree.com it will show you a breakdown of a carb and how it goes together. It may not bee your exact carb but they are all pretty much the same. It also sounds like you may need to rebuild your carb. If you get it back together and it still leaks, I suggest you take it to a small engine repair shop and have them rebuild it for you only cause you need a special tool for the seat and the float will have to be set.
Posted on Dec 28, 2008
  • 19 Answers
SOURCE: Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
Posted on Jun 23, 2009
  • 8 Answers
SOURCE: I have a 1979 ariens GT17 lawn tractor with a
Carburetor- Kohler part # 1205392
Carb gasket- Koh part # 1204101s
Posted on May 10, 2010
vetteman3002
  • 2299 Answers
SOURCE: ariens lawn tractor model 936012
One of your safety switches are not being operated. There is one on the seat, one on the brake, one on the mower deck and some have them on the clutch. But check to make sure that they are all making.
Posted on Sep 14, 2010
1985 Ford Ranger 2.3 starts and idles good. But when put in gear dies until it reaches full temp.
Hmm...........
1985..........
Probably carb? Automatic choke not working? Remove air filter and spray carb with cleaner, Make sure all parts move freely. With engine cold, check automatic choke position. Start and check function as it warms up.
Feb 21, 2016 | Ford Cars & Trucks
Is it a carb problem if I have to spray ether in carb for car to fire. Doesn't always stay running if I do. Carb or fuel line?
Probably fuel pressure issue. Check for leaks, dirty filter, low fuel pressure could indicate bad fuel pump. Normally, a float would cause flooding, but a clogged jet could cause a lean / no start issue. Try some gumout fuel cleaner and a gumout spray clean of the carb and linkages before you get to far into a part issue.
Jul 20, 2014 | 1993 GMC Suburban
Husqvarna riding lawn mower yth 2448 cuts off as if running out of gas after 10 - 30 minutes
Mine would run for about 15 minutes and die. I pulled the carb off and thoroughly cleaned it. Inside the float bowl there is a plastic device held on by two phillips headed screws. Under this device are two tiny tubes with small holes in the side of them. Make sure these are clean. I used carb cleaner in a spray can and a tip cleaner. Make sure to wear eye protection if you use spray cleaner. I reinstalled the carb and, so far, it is working fine.
Apr 08, 2012 | Husqvarna Garden
Go Cart. Starts and runs only on full choke. 4 cycle, gas. Open choke, and engine dies. Sat for over a year. New gas, throttle working, spark ok. Can't find any air leak; carb never off of engine.
Remove the carb, then the float bowl at the bottom of the carb then clean the carb with spray carb cleaner. Spray into each and every drill hole and jet you can find. Use goggles so you don't accidently get cleaner in your eyes. Please, rate my answer, thanks. Reset the air and throttle screws, one and one half turns outward from a lightly seated position. Please, rate my answer. Thanks.
Apr 25, 2011 | Jawa 125 Travel Motorcycles
LEFT GAS IN SNOWBLOWER OVER SUMMER REMOVED THE GAS STILL WILL NOT START
You will need something stronger than regular, fresh gas to clean the carburetor. May I suggest using some Berryman B-12 ChemTool. It contains strong solvents and cleaners that may enable the carburetor to function. Check the dosage, add a little extra in your machine's gas tank. After doing that though, I would remove the air filter housing and spray some carb/choke cleaner directly into the throat of the carb with the choke open. Then choke it to attempt a start immediately. Continue doing it until it "pops" like it wants to start. If that does not work, then pull the plug and introduce some fresh gas or carb cleaner directly into the engine (1 tsp gas). If you get it running, the Berryman will automatically clean the carb and you might be good to go. Post back if needed.
Dec 13, 2010 | Toro Snow Blower Scraper For S200 s620 New...
My poulan wild thing will start but will not stay running without holding the throttle. What should I do?
Get some sta-bil fuel stabilizer. add twice the amount recommended on the bottle for storage to your mixed gas. Empty out chainsaw tank and refill with the new mix. Rub for 2 minutes, then shut off. Remove cover over carb and spray inside carb, soaking it down good and cleaning all internal surfaces visible - allow to sit overnight.
Next day
Spray down carb with carb cleaner for about 15 seconds. Start saw, allowing 2 minutes to warm up and reduce choke. If saw stalls, restart and spray inside carb as it runs with choke on - keep motor at the highest rpms you can as you spray - spray in 2 second bursts, not allowing motor to stall from spray. If it stalls, change sparkplug and try again. You have varnish build up in the carb and are trying to remove it so the carb will work without the choke. This may take some time but it is the exact procedure I used for my Poulan Team Realtree last spring - I spent about an hour spraying and staring before it ran without the choke.
Good luck!!
Nov 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Mower surges its a 5.5hp craftsman mower
Carburetor possibly needs cleaning. Initially, remove air filter, start mower and while it is running, spray some aerosol carb/choke cleaner into the carb thru air intake area. Continue doing this several times but not too fast or heavy to make it stall and then spray it heavily until engine dies. Let it sit for several minutes and then try a restart. If no difference in performance is noticed, carb may have to be removed and cleaned in bath-type cleaner and governor settings will need to be checked also.
Please vote on this solution.
Sep 13, 2010 | Craftsman Garden
I have a craftsman 6.75 hp push mower. It starts
Use fresh gas only first
then if still an issue remove carb.and clean all components and orifices with a good carb. cleaner and air hose or soak it in a automotive grade carb cleaner,spray residue with carb,cleaner and blow dry with air--reassemble and reinstall
May 28, 2010 | Garden
W-7 Case loader will not start. I ran fine, shut
The fact that it will start on ether suggest it's most likely a choke problem. To see if it's the choke cover most of the air intake, if that makes it start that will confirm it's the choke.
If it starts but then stalls when you back off the throttle suggests a vacuum leak. To find a leak use your ether spray it at the base of the throttle body or carb, where vacuum hose connect or look damaged.
If the engine changes you have a leak there. BE VERY CAREFUL USING ETHER TO FIND A LEAK AND HAVE A FIRE EXTINGUISHER HANDY, FIRE IS A REAL SERIOUS RISK USING THIS METHOD.
May 26, 2010 | Milwaukee Tool Case Heat Gun
Ariens Riding Lawn Mower. 42 in. 19 HP Kohler Hydrostatic 960460024 Logo
113 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
