How to bye pass passcode on iphone
Petersoncrystal1 982@hotmail.com
  • Computers & ... Master
  • 27,725 Answers
Your iPhone enables you to add a four-digit passcode which locks your phone to prevent unauthorized users from using your cell phone.
When you enable the passcode, your iPhone prompts you to enter the four-digit code before you can unlock your phone.
However, if you have forgotten the passcode and unable to use your iPhone, you can override the passcode using iTunes the default iPhone management program.
Restore your iPhone back to the default settings to override the passcode.
To do so, connect your iPhone to the computer using the USB cable that came with your phone and launch iTunes.
iTunes displays your device in the left panel under "Devices."
Click your iPhone under "Devices" and click the "Summary" tab.
Click the "Restore" button.
Keeping in mind that restoring your iPhone back to the default settings deletes all the currently saved information.
When prompted, click "Backup" to back up your iPhone.
Click "Restore" again and follow the final guided prompts to restore your iPhone back to the default settings.
When the process completes, click "OK." You should see the "Connect to iTunes" message on your phone.
Keep your iPhone connected to the computer until the "Connect to iTunes" screen goes away or you see "iPhone is activated" message on your phone.
Right-click your iPhone under "Devices" and click "Eject."
Close iTunes and disconnect your iPhone from the computer.
Your iPhone no longer prompts you to enter the passcode.
Posted on Nov 18, 2013
Unlocking my iphone5
Try the steps from here
https://support.apple.com/en-us/HT204306 Forgot passcode for your iPhone iPad or iPod touch or your device is...
Jan 06, 2017 | Apple iPhone 5
Help with how to reset iPhone 5s pass code?
You can reset iPhone password with iCloud Find My iPhone. The detailed steps are shown as below.
Step 1. Go to icloud.com and log in with your Apple ID and password on your computer.
Step 2. Click Find My iPhone. Then click All Devices at the top of your browser window.
Step 3. Select your iPhone from all the devices listed. Click Erase iPhone to erase your iPhone along with its passcode.
Step 4. Use the Setup Assistant on your device to restore the most recent backup of your device.
After the restoration process is finished, your passcode will be erased and all your data will be restored from your iCloud backup. You will now be able to access your iPhone without any passcode.
http://www.leawo.org/tutorial/how-to-reset-password-on-iphone.html
Dec 12, 2016 | Cell Phones
How do i talk off a pass code on iphone 4s ?
Go into SETTINGS, then GENERAL, then PASSCODE . Once you enter your passcode you'll be greater with the options to CHANGE PASSCODE or TURN PASSCODE ON/OFF
hope this helps :)
MM
Apr 25, 2016 | Apple iPhone 4S
How to retrieve passcode to iphone 3gs
You can if it is a simple password- only four numeric digits. If the complex pass code was enabled in your settings then you will have to restore it through iTunes and lose all of your saved info. If you aren't worried about that just turn the phone off, hold the home button down while you plug it into your computer and keep holding the home button down until iTunes recognizes your phone in recovery mode. Then follow the prompts on your screen until it is restored. If you are trying to save the info on your phone just go to iPasswordhelp com and follow the instructions. I'll link the video below.
Jul 17, 2014 | Apple iPhone 3GS Black (16 GB)
I need to disable the pass code on my iPhone 4s
1. Open "Settings App" on your iPhone
2. Then select "General" from left panel
3. Select "Passcode Lock" on right side. Enter your current passcode to continue.
4. Now tap on "Turn Passcode Off". Enter your current passcode to continue. Now Passcode lock will be turned off.
May 30, 2014 | Cell Phones
I forgot my iPhone Passcode. What can I do to unlock it?
iPhone setting:*
- Auto-Lock: 1 Minute;*
- Passcode Lock: On, require passcode immediately, after 15 min or 4 hours etc;*
- Network: Turn 3G Off
Scenario 1: Home screen is active with screen on*
1. Press power button for seconds until asked to '"slide to power off"
2. Slide to power off
3. press power button to turn on iPhone
4.*When asked to enter passcode, touch the "Cancel" key, then slide to unlock
5. bypassed passcode
Scenario 2:*
1. On the screen of being asked to enter passcode, press power button for seconds until asked to '"slide to power off"
2.*Slide to power off
4.*When asked to enter passcode, DO NOT touch any key on the screen, press power button for seconds until asked to '"slide to power off"
5. Slide to power off
6. press power button to turn on iPhone
7.*When asked to enter passcode, touch the "Cancel" key on the right bottom corner, then slide to unlock
8. bypassed passcode
Notes:
1. When Network setting changes to Enable 3G: ON, "3G" signal shows up, passcode CANNOT be passed through
Go to a underground parking lot or a lift where 3G signal is weak, when 3G signal switches to "E" (Edge), passcode CAN be passed through following above steps
2. When no 3G or Edge signal, above steps don't work
Conclusion:
Seems passcode security is related to network status
Possible security hole under Edge
Jan 15, 2011 | Apple iPhone 3G
What is the passcode of wwe smackdown vs raw 2008 flt pc game...
I googled and found this:
smvsr200-8pcomputer
I don't know if it is right or not, but thought you might want to give it a try!
Oct 29, 2010 | Video Game Consoles & Games
I forgot my itunes password and i also I forgot my apple id and could not find it as the iforgot.apple.com says the information provided is not sufficient to retrieve apple id
font.f1 {font: 12.0px Times} General Process:
If you cannot remember your pass code, you will unfortunately have to restore your
iPhone which will wipe everything off the iPhone and restore it back to factory settings.
• The only positive side to this is that your music, video, contacts and calendar settings will still be in tact but you may lose text messages mail and so on.
• One more possibility: if you were able to recently sync your iPhones with iTunes before you forgot your passcode, when you perform a restore, iTunes will put all of the data of your last sync in iTunes (before the passcode issue) back onto your iPhone.
• This is the process which will allow you to regain access to your iPhone.
In order to fix your Apple ID, that I cannot assist you with, as that is an Apple authentication issue.
You may want to contact the iTunes Store via this link below and send their support an email in order to get that Apple ID issue resolved.
Apple Support Link:
iTunes Store Customer Service
Hope this helps!
Regards,
-Mactechtrainer
Oct 05, 2009 | Apple iPhone 3G
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
