Question about Whirlpool Calypso GVW9959K Top Load Washer
Display will not clear. washer will not start
Display appears to be set to start handwash cycle, 29 lit up, water temp and soil level lit. beeps when push clear or start but remains on same display , does not start or clear. I checked and cleaned wires and connections, cleaned ribbon, checked lid, replaced blown capacitors on control board,cleaned boards, it started and completed one cycle but now stuck again showing same display I previously described. any idea what problem is?
  • 27 Answers
If you had to replace blown capacitors on the control board, whatever took them out most likely took out something else on the board at the same time. Causes are many...lightning strike, moisture, bugs etc. I would look carfully at the board with a magnifing glass...you might get lucky and find a short you can fix. If not, your probably going to have to invest in a new control board.
Posted on Nov 17, 2013
4 Suggested Answers
SOURCE: Washer Stuck in Cycle
I checked the lid switch and nothing appears to be broken (cracked plastic). What exactly should I be looking for? Also during the agitator cycle I opened the lid and the washer stopped working. Does that mean that the lid switch is working?
Posted on Jan 14, 2008
SOURCE: Front Loading Duet Washer will not start
I've got same problem, with the door stuck shut, door lock NOT on, water trapped in the machine, and still no solution. 8 pages of messages and no solution.
Posted on Mar 14, 2008
  • 464 Answers
SOURCE: Hello, my washer won't run! Whirlpool Cabrio
make sure the water inlet valve to the machine where the hoses hook up is in good working order. if you don't get water in the machine will lock you out.
Posted on Oct 16, 2009
Testimonial: "this seems like helpful advice on the surface, but after looking up the error code I'm receiving it is something to do with the motor rotor sensor..."
Need self-cleaning instructions....missing manual.
To Self-Clean: 1. Close the oven door. 2. Move the door lock lever to the right to the locked position. 3. Press CLEAN. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. If the door is not closed, beeps will sound and "door" will appear in the display until the door is closed and the Clean pad is pressed again. If the door is not closed within 45 seconds, the self-cleaning operation will be canceled and the display will return to the time of day. If more than 5 seconds elapse between pressing the Clean pad and the "up" or "down" arrow pad, the program will automatically return to the previous display
5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. 6. After 4 seconds, the oven will start cleaning. "LOCK" and "CLEAN" will appear in the display. The cleaning time will count down in the display. To Delay Start Self-Clean: Before delay starting Self-Clean, make sure the door is closed completely or it will not lock and the cycle will not begin. 1. Press DELAY. "DELAY" will flash and "00:00" will appear in the display. 2. Press the "up" or "down" arrow pads to enter the amount of time you want to delay the cycle. Delay time can be set from 10 minutes (00:10) to 11 hours and 59 minutes (11:59). 3. While "DELAY" is flashing, press the CLEAN pad. "CLEAN" will flash in the display. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. 5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. After 4 seconds, "CLEAN," "DELAY," and "LOCK" will appear in the display to show that the oven is set for a delayed clean operation. The delay time is displayed
Apr 21, 2015 | Kitchen Ranges
How to clear codes
i found this in another place
Quick Test Mode
Note: This test erases all faults and memory:
To enter press Spin, Soil, & Power
simultaneously with the power off.
1. All LED's light up and the washer beeps as it
enters the Quick Test Mode.
2. The unit displays the software version for a
second then clears the EEprom.
3. After the displaying the software version, LCD
will display Model information.
If EEEE is displayed the PCB assembly is defective.
For production up to 03/31/2009 Serial **S3**
4. When the version is displayed. Press the following
keys to test the various components.
Effective 4/1/2009 Serial **S4 ** a change was
made.
4. After the displaying the software version, turn
the Jog dial CCW to display "F4". Press the following
Press Temp Key to cycle through the Water Valves in
this order: Cold Main, Bleach, Cold Main & Bleach for
Fabric Softener, Hot, then off.
Press Spin Key to test Motor circuit.
Press Signal Key to test Drain Pump
Press Soil to test door lock - unlock circuit
Mar 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Cycle selector on normal mode. cannot operate water tempertures orsoil level light indicators on a infinityfaf
Ron kundrat,
So I understand that you are unable to operate the water temperatures and soil levels on your infinity washer, while on the normal cycle.
I suggest to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle.
If you are unable to change the water temperature and soil level settings, while in the normal cycle, I suggest to contact your local authorized technician. They will be be able to come out and diagnose the washer and see why you are unable to change the settings.
-Best Regards-
Jan 13, 2014 | Frigidaire Washing Machines
The times seem to have changed on the settings for soil levels. For instance, the quick is 50 minutes and the normal is 84 minutes. That does not seem right. Is there any way to set them different?
Answer to your question "Is there any way to set them different?" Short answer is no. The Maytag Neptune like many other washers that display a time of cycle first start with an estimated time this relays a lot on the last cycle ran. But, more importantly it also takes into consideration other washing options. For example, lets say that your quick wash cycle used to only display 35 min. now if you select an extra rinse option the time will increase from that 35 min. to a higher amount of time. This is due to the longer time it takes to go through a second rinse cycle. The MAH5500 if I'm not mistaken also has a heater in it so there are options such as sanitize which takes 120 degree hot incoming water (suggested temp. for hot water heaters) and heats it to approx. 165 degrees. And as you can imagine this takes a washer some time to do this (increasing wash time). If you would like to lower washing time check the washing options and remove any that are not needed at that time; pay close attention to extra rinse cycles and the soil levels that are selected. Hope this helps. Cheers.
May 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
I have a kenmore Oasis that powers up but wont start
Activate the Console and Indicators Diagnostic Test Mode to check the functionality of the .
Console and Indicators Diagnostic Test Mode Activation
  1. While in standby mode, press the following button sequence within four seconds: SOIL LEVEL>WASH RINSE TEMP>SOIL LEVEL>WASH RINSE TEMP
  2. Press the START button within five seconds of "dt" showing on the display. All indicators should turn on and "88" is displayed.
  3. Press START again. The two-digit display and the status indicators turn off while all other indicators remain lit.
  4. Press START again. The two-digit display and the status indicators turn on while all other indicators remain lit.
  5. Rotate the WASH CYCLE selector back and forth. The indicators will switch on an off.
  6. Press the buttons to check the function. The indicators will switch on or off and a beeping sound will be heard when a button is pressed.
  7. Press STOP or POWER button to exit diagnostic test mode.
  8. If no indicators light up or if no beeping sound is heard when a button is pressed or if some buttons do not light up indicators when pressed, check the user interface board and its connection to the main/control board.
  • Unplug the machine.
  • Remove the three screws on the back of the console.
  • Lift the console off the cabinet.
  • The control board is located on the right side of the console viewed from the front of the machine. Disconnect the middle wiring harness connector on the right side of the control board near the pressure transducer hose.
  • Clean the connector thoroughly to ensure a good connection.
  • Reinstall the console and reconnect power.
  • Run the diagnostic test once again.
  • Replace the user interface board if it fails the test once more.
Refer to the next post if no problem is found on the user interface.
Jan 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Does not go into self clean only beeps
here is a link for your owners manual click here
To set Self-Clean:
2. Press the appropriate Clean pad.
• CLEAN flashes.
• SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
• “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning
settings.
“HVy” (Heavy Soil, 4 hours)
“MEd” (Medium soil, 3 hours)
“LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs
the self-cleaning time.
5. After four seconds, the oven will start cleaning.
• If the door is not closed, beeps will sound and ‘door’ will
display. If the door is not closed within 30 seconds, the
• CLEAN will appear in the display.
• LOCK will flash in the display. Once the door locks,
LOCK will remain steady.
• The cleaning time will start counting down in the
display.
Please take the time to rate this solution
Jan 30, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Water level buttons keep cycle through continuously and the estimated time changes with the soil level.
hi thanks for the question. the actions of this washer that you are describing is normal these washers are a real pain in the you know what but it is normal welcome to the way they are building them to-day
Sep 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Steam cycle runs on every setting
The steam will only run on certain cycles. If you look at your dial you will see a pink line which indicates which one. Your unit does have a recirculatting pump, maybe you are confusing the two. One way to check is to run a delicate cycle. During the operation press the wash/rinse and soil level buttons together. Hold them, a display will pop up with readings in the second coloumn, and second row it will display the tempurature of the steam generator in ceilsus. This will confirm whether or not it is on.
Sgt. 48
May 29, 2008 | LG WM2688H Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal De
