Question about Blu Q110 Samba Q - Unlocked Phone - Us Warranty - Retail Packaging -
Sim 2 slot does not work
Help.. is there a setting that needs to be set?
    New Friend:
  • 13 Answers
Yes. Path is Menu>>Settings>>Dual Sim Settings>>Change to either the other sim or to both of them.
Posted on Dec 08, 2013
2 Suggested Answers
  • 246 Answers
SOURCE: how do i get dual sim to work? sim 2 does not work and i cant find anything in settings
format it in phone settings and try it
Posted on Nov 17, 2013
I have exactly the same problem. My cell is also a ZTC K300.
OK, try troubleshooting the problem like this: Go to the Sim's profile in the background, it should be in the third page. It have a sim icon, tap on it and verify that the dual sim is checked. Now go to the settings in the main page, tap it and go to the network set up, tap it, now here if you have both sim cards install, choose the one that you are having trouble with, I believe that is sim slot #2, so choose sim 2, and tap on network set up, and choose the network that service the sim card. If that doesn't work, check the imei number for the sim 2, and compare it from the one in the back cover, if they don't match, you need to change the imei number. Go to www.mysciphone.com and download a program that allows you to change the imei, just in case, good luck.
Sep 05, 2009 | Cell Phones
I've i9+++ phone. It does not work with two sims inserted
It should just work - about the only thing I can think of is that there is an option under settings that controls the dual SIM mode, and that should be set to "Dual SIM open".
Jul 03, 2009 | Dual Electronics CECT P168 Cellular Phone
Phone reads second sim invalid
Go to Settings/Dual SIM settings and choose Dual SIM open. Perhaps this is the problem.
Jun 19, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
My sciphone i68+ isnt reading my sim card it picks it up when i first turn it on then when try 2 make a call it stop pickin it up can you plzz help me?
i had same problem and have eventually solved it!!! Insert sim card into bottom slot with the gold face up. Make setting on phone got sim card 2 (not 1) You do this under UART setup (that's in the settings menu on the opening screen) and also under the profile menu highlight Only SIM2 open.
This did it for me and now can make calls with "call 2" option.
hope it will wotk for you
Jun 12, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Sim card problem
make sure the sim card is inserted properly. sim card slot 2 is the one away from where battery cover (against the phone) the gold chip will face up towards you. sim card slot 1 is the one slightly elevated gold chip will face down. if you are sure you have it inserted correctly, follow the steps below that came off the help disc i have offered. Works for I9 and I68.
Emergency calls only, then try these steps;
1.) Shut down the phone, remove the SIMS, and replace them back in the slots in the
correct manner again. It may just be that the SIMS aren't in correctly, not pushed far enough
into the slot, or their metal grid isn't making good contact with the SIM's slot pins. Try to
wedge a tiny piece of paper, placed against the side of the SIM without the metal contacts, between the phone and the SIM so it makes the SIM's metal contact points fit up against the phone's SIM slot contacts a little more snugly.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
May 04, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I9/168 + sci phone vodafone & vigin work on sim1 slot only ?
Make sure the sim cards are inseted properly, SIM 2 wich is the bottom slot the gold chip has to fase up, (yoe see it when you insert it) sim 1 wich is the top, the gold chip faces away from you, so basically with both sims in the chips face each other. also make sure both sim slots are turned on in your phone settings.Settings => Dual SIM settings => Choose the proper SIM setup => OK in this case you would select Dual SIM open then OK.
May 03, 2009 | Dual Electronics CECT P168 Cellular Phone
Just got new cect i68 phone off ebay
You need to call T Mobile because you bought the phone off Ebay. It has to be re registered in there system and set up under their network regardless of any other factor. They have to put their numbers in the Nam1 and Nam2 parts of the phone with the EIM and CDM. That may mean nothing to you but it makes your phone run!! Give T Mobile a call from a LANDLINE phone
Mar 17, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Only one sim works
there are two different lines for different sims....as LINE 1 AND LINE 2...there is an option for changing the line. then u can use both the sim. i hope this works. and if problem persists, u can contact the dealer. ur cell is under varranty period so dont worry. if the cell is faulty, u can claim to replace the set.
take care
Dec 16, 2008 | Microsoft Windows XP Professional With...
I have a Rocada Xphone and am unable to get it to ring, text or make calls. It is saying something about 2 SIM cards.. what can I do?
I have a rocada xphone (gold) and it has two sim slots but you can go to the settings app and select to use only one sim. I only use one because i am with t mobile. I had to call t mobile so they could send me the t mobile settings and they sent it in a text message. Now i have the internet and can send and recieve pic msg.
1. press settings on your phone
2. dual sim settings
3. only sim1 open (make sure that is the one you put your sim inside because it has two slots and they say sim1 and sim2)
so when you go back to the main screen at the top there should be an X by the 2. and it will say sim2 closed on the main screen.
Dec 09, 2008 | Nokia 5140i Cellular Phone
Blu Q110 Samba Q - Unlocked Phone - Us Warranty - Retail Packaging - Logo
55 people viewed this question
Top Blu Cell Phones Experts
Hjalmer Lamminen
Hjalmer Lamminen
Dustin
Dustin
Are you a Blu Cell Phone Expert? Answer questions, earn points and help others
