Question about Electrolux EW1000i Front Load Washer
Eifls60jiwo will not start, says pause
  • Official Brand Answer
  • 4,342 Answers
Good Morning Chris, thank you for allowing me to assist you!
If you are receiving error code PAUSE, it commonly indicates door of your washer is not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the appliance by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn your washer on. If the issue persists, then the washer could possibly have a faulty door latch or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Posted on Nov 18, 2013
The orange on/off button lights up. however the start/pause button does not.
It's hard to tell by the way you've phrased the question whether or not the button is doing what it is supposed to do, or if it is just the light indicator that is not working. So, I will answer both scenarios. // Press start button fully until you hear machine start; (usually less than one full second). In other words, hold button in until ''start'' is _heard_. After start has begun, holding button for 3 full seconds will ''pause'' the cycle. After ''pause'' pressing button again (just like first time) will restart cycle (i.e. ''take it off pause''). But while ''paused'' holding the button in again for any longer than a fraction of a second will cancel the wash. // TO CLARIFY: Press button for approx 1 second to start wash. After start has begun, pressing button for 3 seconds will ''pause'' wash. While ''paused'' pressing button again for less than a second (i.e. ''quick press of button'') will ''resume'' wash. Also, while ''paused'', pressing button for longer than a second (usually 3 seconds) will cancel the wash. // If the machine is (otherwise) working correctly, and your complaint is a light not lighting, then it is just a bad LED light. Best bet is leave it alone. Or, you could buy a new switch if the LED is _inside_ the switch. If the LED is on the control panel, then do yourself and big favor and don't mess with it.
Aug 15, 2015 | Washing Machines
How do I pause while recording? I can pause while playing back but can't seem to figure out how to pause a recording then resume, it just stops and starts a new clip. Please help. (My handycam is cano
The default is to start a new clip every time you press the stop button, but in settings you might be able to tell the camera to continue with the same clip provided you press record again with a set time. Not sure why you want to do this though - it's much easier to edit using small clips than very large ones.
Aug 23, 2014 | Canon FS100 Flash Media Camcorder
Start/pause button will not release
Could be just dirty, e.g. fizzy drink or coffee spilt. Try cleaning with real care and detail around the edges of the switch, use a cocktail stick to get into the gaps.
Dec 07, 2013 | Washing Machines
My frigidaire dyer comes on then the pause message appears. These are new appliances.
Hello barbarada180 - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Jan 02, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Pause error unit will not wash
Hello cvaughn37_cv - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Nov 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Pause lock keep showing up on screen
Hi Lance - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Sep 16, 2012 | Frigidaire Affinity ATF7000E Front Load...
When pressing start on my frigidaire washer LTT2940FE1, It says pause and won't start.
Reset the unit at the household circuit breaker and retry. PAU means the unit is paused either by a blockage and the sensor won't let the unit continue, or it was manually paused by a button press.
Jul 26, 2012 | Frigidaire ATF6000ES Front Load Washer
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
May 20, 2008 | Maytag Neptune Washer
Electrolux EW1000i Front Load Washer Logo
76 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
