Question about Electrolux EIFLS60JIW Front Load Washer with IQ-Touch Controls Featuring Perfect
Eifls60jiw washer goes right to pause
Washer goes immedietly to pause
    Problem Solver:
  • 10 Answers
You probably have a stuck button on the touch pad. Try pressing it repeatedly firmly it may unstick.Otherwise you may need to call a pro to diagnose the problem.
Posted on Nov 17, 2013
How do I force washer in drain cycle?
Hey Nick, to force your washer to drain is really easy. You will need a bucket and some extra towels. Simply remove the drain hose from the house drain pipe and lower into the bucket. If your bucket fills up, simply raise the hose above the level of the washing machine and the water flow will cease. Please reconnect with us if you do need any further assistance. Best Regards, JK
Oct 25, 2015 | Electrolux EIFLS60JIW Washer
User manual
Maybe posting the make and model of your unspecified washing machine, could look for a manual, if available
May 19, 2015 | Washing Machines
How do you remove the dispenser cover for an electrolux EIFLS60JIW0 PS3490379?
Good Afternoon Friend,
I understand that you are trying to remove the dispenser cover for your Electrolux washer, model# EIFLS60JIW. The cover is locked in 3 areas of the dispenser, where the cover meets the dispenser. The right side, the middle, and the left side. All you will need to do is pull up on the cover and it should come apart from the dispenser. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 24, 2014 | Electrolux EIFLW55HIW Front Load Washer...
EIFLS60J ERROR 21
Hello foureor92424, thank you for allowing me to assist you!
If you are getting an error code E21, it usually means that your washer is not pumping out water fast enough. First, check the drain hose for any restrictions or kinks. If you have check the hose and it appears to be clear and free, then potentially the underlying issue may be the main control board or pump. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
Best regards!
Jan 26, 2014 | Electrolux EIFLS60JIW Washer
"no water" message
is the water on? sorry had to ask. after that, you have a valve fault (probably) or board fault (unlikely). with a multimeter check there isn't an open circuit over the valve terminals. if so, get a new valve and chuck it in.
Nov 10, 2013 | Electrolux EIFLS60JIW Washer
Washer gets to rinse cycle and starts to pump water then stops?
Before hitting any buttons you need to write down the fault code. As soon as it starts beeping take note of which lights are on along the top row. There are 8 lights. Count from the right and tell us which number light is on and which are off. That will tell us the error code and what it means.
May 30, 2017 | Fisher and Paykel GWL11 Top Load Washer
Will not drain and spin keep beeping with error E20
  1. Remove the 2 screws on the bottom and the front access panel comes off.
  2. Pump is on the right, remove hoses from it, remove pump from machine and remove whatever is in the pump.
Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin LEDs should light. Any error codes should be displayed when holding those keys.
Feb 27, 2011 | Frigidaire ATF6000ES Front Load Washer
Goes into Pause mode during Delicate cycle. Model
Did you ever get this fixed? mine is doing the same thing
May 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Electrolux EIFLS60JIW Front Load Washer with IQ-Touch Controls Featuring Perfect Logo
102 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
