Question about Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER
Only hot water comes out , no cold water
Hot water comes out , but no cold water will come out . The anti scald technology is not working .
Hot water is very slow coming out spout. Cold water comes out fine with good pressure..
the anti scald is adjusted too low. its located under/behind the handle. it usually has am allen wrench head. remove the handle and adjust it all the all the way to hot that should fix it. on some models you can remove the entire thing,but on some that will cause the handle turn 360deg because in some models its also the stopping point of the handle. hope this helps
Dec 11, 2012 | Jacuzzi Home
No cold water
Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
Apr 01, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
No cold water
Behind the handle there is a dial to adjust water temp cold and hot you can remove it and replace it a 1/4 turn til you can get both cold and hot. It is a anti scald it may have been put in wrong.
Make sure the cold water line is not blocked coming to valve and is open .
Mar 15, 2010 | Danze & Single Handle Tub And Shower...
Not enough hot water in the shower even if I turn the handle all
Your valve has an anti-scald feature which automatically adjusts the water temp if cold water is diverted to another location, e.g., a flushed toilet, washing machine filling, etc. Most valves have an adjustment screw to allow you to set the temp. Since each manufacturer is different you'll need the manual or contact the manufacturers support. BTW, these anti-scald valves are being added to building codes in many parts of the U.S.
Mar 07, 2010 | American Standard Cambridge 5' Americast...
Hot water pipe hot going into mira shower but no hot water coming out
need to adjust the anti-scald [protection] new systems are shipped in cold position and u adjust it to ur comfort
Feb 15, 2010 | Water Pik Hand Held Shower
How to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
Feb 10, 2010 | American Standard Bath Faucet Ceramix...
My Moen Posi-Temp tub valve runs only very cold or very hot. whats wrong?
Your Moen valve is equiped with an anti-scald device (as part of the valve cartridge) which prevents someone from getting scalded by hot water if there's a sudden demand for cold water, i.e. a toilet flush, washing machine filling, etc. Fortunately Moen stands behind their products and will provide a new cartridge.
Contact Moen and describe your problem.
Jan 26, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Hudson Thermostatic Problem
try this.
if you have anti scald device installed in the valve, take it out. the anti-scald device is to keep the hot water from pouring out in case the cold water pipe is not functioning. In general sense, it is a good idea, however, it also mixes too much of cold water, therefore you don't get eough hot water.
Jan 10, 2009 | Home
Have a combi boiler and the hot water from my taps are running cold to luke warm. My British Gas engineer has told me it is nothing to do with the boiler but is caused by a faulty thermostat cartridge in...
Modern shower valves have an "anti scald device" in them to prevent scalding from to hot water.
They come preset at 120 degrees.
Sometimes they can start to malfunction and all you get is warm, not hot water, they can also be intermittent.
This will only effect the shower valve though, not the other faucets.
Dec 06, 2008 | Heating & Cooling
Ace Hardware OAKBROOK COLLECTION DESIGNERS CHOICE TUB/SHOWER Logo
52 people viewed this question
Top Ace Hardware Home Experts
guitar zan
Are you an Ace Hardware Home Expert? Answer questions, earn points and help others
