Question about Whirlpool GB2FHDXWB Refrigeration : Refrigerator : Bottom Mount
How do i fix ice building up on bottom of freezer which the water begins to leak out on to the floor
How do o fix ice building up on the bottom of freezer which the water begins to leek out on to floor
tech master
  • 120 Answers
SOURCE: Whirlpoll Freezer model EV190NXWN00 not freezing
it sound like is not defrosting if is upright freezer. open the back wall jerry if that evaporator is full of ice then it has cut off all the air flow and in return that is why is not freezingif you know how to use the voltage meter you might need to check continuity on the heater if it check ok then repl the bimetal part# 4387499 and timer 482493 when repl time follow the wiring schamatics realy carful look for the right clor harness in the instructions and then just let it defrost or use the hair dryer
Posted on Oct 19, 2008
SOURCE: ice build up
You should to check the Whirlpool Gladiator Freezerator's door sealer to make sure all rubber or plastic seal very well to prevent air humidity come in to build up frost fast. Also, you have to defrost completely and wipe with cloth or paper towel to absorb all waters out and let it dry completely to prevent frost build up.
Posted on May 08, 2009
  • 6 Answers
SOURCE: I have an upright with ice maker. EVL201NXRQ04.
Is the ice tray that fills level? this may be over flow from the tray filling sequence
Posted on Sep 15, 2009
  • 454 Answers
SOURCE: Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Posted on Mar 13, 2010
heatman101
  • 43501 Answers
SOURCE: ice building up in bottom of freezer drain tube blocked
Check out this tip it will help you fix that...
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Apr 19, 2010
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
Upright freezer,automatic defrost. problem: ice build-up in the bottom.
get down on the floor and look along the bottom of the door to make sure that the door seals are touching.if not and you have an air leak it will cause frost.if its ice and not frost then check all vents/drains are clear.
Mar 17, 2010 | Freezers
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 | Freezers
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice at the bottom of freezer ice at the bottom of freezer, defrost water not draining
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 30, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Apr 14, 2009 | Freezers
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Whirlpool GB2FHDXWB Refrigeration : Refrigerator : Bottom Mount Logo
56 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
