Question about Garden
About 5 min. after starting white smoke will pour out the the muffler for three or four min. then everything is okay.
About 5 min. after starting white smoke will The oil level is okay. There appears to be an excessive amount of oil in the air filter where the crankcase vent tube is connected.
  • Garden Master
  • 2,478 Answers
Check for air leaks around air filter.
Posted on Nov 17, 2013
  • 109 Answers
SOURCE: lawn mower blowing out white smoke
Change the oil...it is diluted with water or gas
Posted on Apr 21, 2009
rburroak
  • 14 Answers
SOURCE: MTD Yard Machine 22'', 4.5HP, 190cc push lawn mower won't start
The primer bulb might be damaged, or the carburator diaphram could have been damaged if carburater cleaner was used.
Posted on Jun 19, 2009
  • 130 Answers
SOURCE: Oil is leaking from the muffler and white smoke is coming out.
this is more severe.if you are not a small engine person 3 things get a book on mower or take to shop or get a new mower.
not trying to be funny but if you dont know its going to be hard for you to fix the valve guides are bad need to replace will take speical tools to fix.sorry
Posted on Jul 22, 2009
SOURCE: 6.75 Craftsman Eager1 Lawnmower, My son had this
Aloha, its a Tecumseh/Craftsman mower and at the end of that little black hose under the flywheel is a crankcase breather/filter, you can carefully pry it out with a screwdriver and clean it with solvent or gas and slip it back in and the hose goes to the carb on top there is a nipple, but clean it first
Posted on Sep 27, 2009
SOURCE: blue/white smoke from muffler
I had white smoke from my muffler after filling a dry push lawn mower gas tank and I guess I over filled the tank. This is a practically new mower. I looked at the mower manual and it said over filling the gas tank would cause white smoke from the muffler. My question is now did I ruin the engine, ruin the muffler, should I drain the gas tank? The manual does not say what I should do.
Posted on Jun 08, 2010
I was mowing Yest and White smoke started pouring out the Front Could that be bad gas or what
no its not gas. it could be a few things. look on the front of engine and see if it is leaking oil on the muffler. could be rings are bad. could be a valve has stuck. either way it sound like it is a project. when white smoke comes out exhaust it is usually engine failure.
May 12, 2016 | Garden
Chugging motor, lots of white smoke.
oil has either run into the muffler or the air filter assembly clean out and good to go.
May 22, 2013 | Craftsman 675 Torque 190 cc 21" Push Lawn...
When you start engine white smoke pours out and oil is blowing out 2 feet out of muffler.
Hi michelley636
Check your oil level, it sounds like it is too much oil in the crankcase causing it to burn in the combustion chamber
Bud
Apr 29, 2013 | Briggs & Stratton Garden
I have a brand new masport mower, too much oil was put in and it was blowing white smoke, dripped it up drained some out few days later start to mow it'll mow for a few mins the blow alot of white...
make sure oil is at the correct level , remove exhaust muffler drain all oil if any, reinstall and run it until smoke clears , it should not take too long . Make sure engine is cool when working on any component
Feb 25, 2013 | Garden
Dear All, My Name : TSN Prasad My Bike : Hero Honda Glamour 2011 KM Covered : 1250, First Service Done at 540 KM My Problem : heavy White smoke arrives only when engine is Cool Sir, my bike exhaust heavy...
Hi, TSNP your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is at the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on start-up is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on start-up may be caused by worn out valve seals or a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.xbhp.com/talkies/help-me/32061-hero-glamour-white-smoke-exhaust.html
https://www.quora.com/White-smoke-is-coming-from-exhaust-2009-glamour-bike-12000-km-run-less-used
Hero Honda Glamour 2007 service manual DOWNLOAD FREE FULLMANUALS COM
Hero Motocorp Glamour 125 Disc User Manual
http://www.partsfish.com/page/oem-parts-for-honda
Apr 07, 2017 | 2006 Hero Honda Glamour PGM-FI
I changed the oil and white smoke poured out of the exhaust. Also there was oil spewing all over.
Depending on if you laid the engine over on its' side, there could have been oil in the muffler. It may take some time to "burn" this off. It will also come from the muffler. Given enough time the oil will get hot and smoke off of the muffler. Then it will no longer smoke.
I hope this answers your question.
Apr 03, 2011 | Garden
I just bought an 03 RM250 and the dude told me that he had just rebuilt it. I picked it up at night so I didnt notice the smoke then. When it runs man it pours blue/white smoke terrible. I thank it may...
Is this bike a two stroke or four stroke.Meaning do you mix oil n gas,or dose it run on straight gas .If this a two stroke,its normal to blow blue smoke,but not that bad.Sounds like the person before you put to much oil in gas or piston rings are shot.There are exact oil to gas ratios you must follow with a two stroke engine.If you dont, you can have all kinds of problems.
Feb 08, 2011 | 2003 Suzuki RM 250
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Muffler blowing white smoke
take it back the engine has a blown head gasket or cracked head all cost over 1200 to fix
Mar 15, 2009 | 1997 Dodge Caravan
Garden Logo
99 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
