Question about GE JGBP33 Gas Kitchen Range
GE gas range JGBP33WEH3WW totally dead after self clean
During self clean, head loud pop, range totally died. Oven does not work, burners do not work, control panel blank
  • 26 Answers
There may be an oven over temp thermal switch that has opened and needs to be replaced. Also you need to determine why the temp got so hot to cause this safety device to do its job. This might be a failed cooling fan
Posted on Nov 20, 2013
SOURCE: I have lost my manual to my GE Profile Gas Range, self cleaning, convection and conventional oven
what does f2 mean when I am self cleaning my ge profile oven.
Posted on Dec 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: oven burner makes a popping or whistling sound during baking cycl
STOP>>>>STOP{>>>STOP>>>
You have a gas leak in the oven.
Get this fixed immediately.
Posted on Feb 21, 2009
  • 23 Answers
SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
Posted on Jun 20, 2009
emissionwiz
  • 76673 Answers
SOURCE: ge self cleaning oven wont shut off
replace the oven control circuit board.
Posted on Jun 21, 2009
SOURCE: How do I clean a GE gas range (self-cleaning oven?)
What do i clean the burners with ? the round surfers is harder to scrub, what do you advice .
Posted on Jun 22, 2009
Have spectra extra large self clleaning oven never had trouble oven does not work i was baking and it worked fine. Then when I went to bake later and turn the oven on it clicked but never got hot. Yhe...
Hello - Most troubles with ranges occur during the "self-clean" cycle. The problem- no lower burner- could be a bad ignitor. Part is 40-75$ Fairly easy to install, or have done for about 75-100$ Let me know if info helps- I have more if you need it - Thanks- ED
Mar 03, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My maytag gas oven model #MGR5755QDW makes a loud poof noise when first turned on. It doesn't do it all the time and it only happens when it is first lights.
You are getting a delayed ignition fom the oven burner. Either the ports on the burner near the ignitor are clogged or you have a weak oven ignitor. part # 12400035 @ $70.00
Apr 08, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Display not working
The display needs to be replace. Check all the wiring also to make sure nothing over heated
Feb 14, 2009 | GE Profile 30" Self-Cleaning Freestanding...
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
GE JGBP33 Gas Kitchen Range Logo
110 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
