Question about Veho Vss-009-360Bt M4 Portable Rechargable Wireless Bluetooth Speaker With Track Control
Connection problem Bluetooth
Connection problems. The PC (Windows 7) cannot establish the connection.
How do i get bluetooth working on my aspire5535 laptop
Activate the Bluetooth features of your Acer Aspire to unlock your laptop's wireless function. Bluetooth technology allows your computer to control and share data with external devices without having to use a connection cable or download drivers.
In order to establish the connection with other enabled devices, you must first enable the Bluetooth antenna so other devices can locate your computer.
Press the "Bluetooth" button found just above the keyboard.
The LED above the button should illuminate.
Click "Start," "Control Panel" and "Add a Device."
Your Acer scans for other Bluetooth devices in the area.
Click the name of the device in the window that appears, and click "Next" to establish a connection with the external device.
Microsoft bluetooth support
http://support.microsoft.com/kb/883259
Aug 05, 2013 | Acer Aspire 5535-5050 Notebook
Bluetooth
When you connect a headset (after pairing you double-click the headset's icon and click the headset service) you will hear a beep on the headset itself. When you "answer" this by clicking the appropriate button then the connection is finally established - only then the sound is routed through Bluetooth.
It seems you are doing this already. But the problem is that this only affects programs that start using sound after the connection is established, or programs that don't keep the sound channel open. I am not sure that MSN does it. You could exit MSN, connect the headset (confirm the sounds are coming through it by using Windows Media Player for example), then start MSN again and see if it makes a difference.
Aug 12, 2008 | Pioneer AVIC-F900BT Car GPS Receiver
My biuetooth does not work properly in my acer aspire5750
Aug 05, 2013 | Acer Aspire 5500 5570-2609 Laptop
Enable bluetooth
Aug 03, 2013 | Acer Aspire One D150-1587 Netbook
Acer Aspire 3618AWLCi bluetooth
Bluetooth technology allows your computer to control and share data with external devices without having to use a connection cable or download drivers. In order to establish the connection with other enabled devices, you must first enable the Bluetooth antenna so other devices can locate your computer.
Press the "Bluetooth" button found just above the keyboard. The LED above the button should illuminate. Click "Start," "Control Panel" and "Add a Device." Your Acer scans for other Bluetooth devices in the area. Click the name of the device in the window that appears, and click "Next" to establish a connection with the external device.
Feb 03, 2013 | Acer Aspire Computers & Internet
How to turn on the webcam
It should be located in"devices and printers" and or in my computer or computer in Windows 7. You may also connect with a chat software like Skype. Thanks for using FixYa
May 14, 2011 | Acer Aspire One Netbook
Is there a way to establish a mobile - PC bluetooth connection or it requires a bluetooth adapter?
Yes, laptops can be connected to either a cellphone or another laptop using bluetooth device. Your laptop has an optional bluetooth adapter. If you didn't get that feature, you can buy a USB bluetooth adapter dongle. Click here to see a sample.
May 16, 2010 | Dell Latitude D600 Notebook
Use of polaroid PoGo Zink printer with PC
The PoGo can connect to a PC with Bluetooth only. Once you establish a Bluetooth connection with your PC, simply copy any JPEG file to the PoGo using Explorer. No printer driver is needed, just copy the file to the PoGo over the Bluetooth connection.
If your PC doesn't have Bluetooth, you can buy a USB Bluetooth dongle for $5-$20.
May 04, 2009 | Polaroid PoGo Digital Photo Printer
Any way to connect to a PC with Blue Tooth
No printer driver needed. Just establish a Bluetooth connection between the PC and the PoGo, then send the file to the PoGo using Explorer. In Windows you can right click on the JPEG file and send to - bluetooth device.
Feb 15, 2009 | Polaroid PoGo Digital Photo Printer
Veho Vss-009-360Bt M4 Portable Rechargable Wireless Bluetooth Speaker With Track Control Logo
Top Veho Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Veho Audio Player and Recorder Expert? Answer questions, earn points and help others
