Question about Pentax Photography
Repair manual pentax clip on meter - Pentax Photography
I recently dropped my Pentax K1000....oops! The only damage I noticed was a small dent in the metal side of the lens....hardly even noticeable. But now, the focus isn't working, and the light meter doesn't...
Unfortunately, this is a serious problem.
If the focus ring is not working then there is serious damage inside the lens. This cannot be repaired easily and must be taken in for repair.
As for the light meter, this is slightly more worrying as it is damage inside the body. It could be something as simple as the battery contact. But it could also be somehting more serious.
I would recommend taking it for repair.
If repair turns out to be too expensive I suggest you have a look on ebay. Pentax cameras are available with a wide range of prices and so are compatible lenses. A good upgrade would be a Pentax MX or even an LX if you can afford it. The ME super is also an excellent model if you want soemthing simpler.
Feb 22, 2011 | Pentax K1000 35mm SLR Camera
Does the Pentax M7-Z have a light meter?
Yes, it does. If you need a manual, you can download one from
http://butkus.org/chinon/pentax/pentax_mz-7/pentax_mz-7.htm
Sep 20, 2010 | Pentax MZ-7 Film Camera
The right lens of my Pentax Jupiter 8x20 MCF II slips in and out.
It's not a repair manual you need, it's a new objective retaining ring.
You will need to find your Pentax agent and have them put in for repair.
Jan 21, 2010 | Pentax Optics
Pentax me super camera, not working wind on lever
The clip spring broke jambing the advance gear. by forcing, the tab on the advance shaft broke.
take or send your camera to a camera repair shop for an estimate cost to repair.
there are no new parts for this model so the repairs could be expensive.
there should be no cost for an estimate.
Dec 10, 2009 | Pentax ME Super 35mm SLR Camera
PENTAX K1000 CAMERA EXPOSURE METER IS NOT WORKING
Clean the battery cap and contacts with a pencil eraser including the cap threads.
there are no new parts available for this model Pentax, so a good used part repair could be expensive.
An inexpensive hand held light meter might be the way to go if the cleaning did not work, and the camera is otherwise working good.
Nov 05, 2009 | Pentax Photography
I have a pentax zx-60 and i am taing a photo class how do i set the camera on maual but still be able to change the aperture
Use the exposure mode to metered manual mode using the [mode] button until the [M] is selected on the far right of the LCD screen.
The [M} is to the right of the [Tv] and [Av] selections.
Also, there is a switch on the camera body where the lens is attached... switch from AF to MF (UP position) (AutoFocus to ManualFocus).
The meter inthe viewfinder will continue to work so that tou can use the built-in meter to assist in your manual configfuration.
Good Luck! Photography is a great hobby and profession!
Sep 17, 2009 | Pentax ZX-60 35mm SLR Camera
I have a pentax zx-60 and when i turn it on all it says is av and i am trying to get it to say manual how do i do that
I love my Pentax!
Use the exposure mode set to metered manual mode using the [mode] button until the [M] is selected on the far right of the LCD screen2.gif.
Also, there is a switch on the camera2.gif body where the lens is attached... switch from AF to MF (UP position) (AutoFocus to ManualFocus).
Exposure needle not working
clean the battery cover and contact with a pencil eraser making sure the cap threads are also clean.
this is a fairly expensive repair if the meter or circuit board needs replacing ( no new parts are available ).
if the meter still does not work, and the K1000 is in good working order buy a inexpensive hand held light meter.
Jun 11, 2009 | Pentax K1000 35mm SLR Camera
Will no longer recognize 4gb sd cards
F4shsk1
are you sure the camera is a Pentax K1000.
the K1000 is a manual 35mm film camera, the only electronics in it are for the light meter. plus a circuit for the flash connections.
Apr 14, 2009 | Pentax K1000 35mm SLR Camera
Photography Logo
27 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
