Question about Gateway Ne56r31u Intel Celeron B830 X2 1.8GHz 4Gb 320Gb Dvd /-
NE56R31u power on became intermittant, then stopped working altogether
The power "on" function on my NE56R31u laptop began to work intermittently, that is, when I went to start it, I would half to press it multiple times, before it would start, until finally, it stopped functioning altogether, and it won't start at all, now.
  • 48 Answers
Its BIOS need to be Re-set or Re-flashed only done by Technician.
Posted on Nov 17, 2013
Subwoofer channel no longer has output
Is your sub powered (amplifier built-in)? If so, connect your MP3 player directly to the sub input and see if you hear audio. If you do hear audio, check for cable problems from Panasonic to sub input. If the sub is unpowered then it's either the speaker wiring, an intermittent sub and/or your Panasonic at fault.
Mar 22, 2015 | Panasonic Sa-ht70 Home Theater Receiver 5...
During a recent snowstorm, the weight of the snow was apparently too much for the rear wiper. It stopped mid-stream and is stuck. Simultaneously, the intermittent function of the front wipers also quit. ...
Check fuse no. 11 (10A) in the driver's under dash fuse/relay box. I suspect it is blown. It provides power for the rear wiper, both washers, and the intermittent wiper function for front and rear. It probably blew when your rear wiper got stuck.
Jan 31, 2011 | 2003 Honda Odyssey
The Bake ignitor in our Amana Gas Range (model #ACF3375AW) recently began to only work intermittently. Now it doesn't work at all. The Broil ignitor works fine. Any ideas? Thanks! Dana - Minneapolis
Hi Dana from Minneapolis...you need a new Bake ignitor, which is also called a glow coil. When it's working properly it glows a white hot colour and as it wears out it will glow an orange colour and needs to be replaced, this is why it began failing and then quit altogether. This is a part that requires an authorized gas technician to install for you. Good Luck.
Jan 26, 2010 | Amana Kitchen Ranges
Started to work intermittently, then just stopped
Is the controls to this machine in the hose. If so, then the hose is going bad. That is pretty typical for these models,
Nov 25, 2009 | Kenmore 25512/ 25513 Progressive Canister...
1998 Nissan Quest - rear blower not working
SInce you indicated that it was working intermittently then quit working altogether the most likely culprit is probably a bad blower relay . The Contacts in a relay will sometimes burn and intermittently still conduct for while until they get so burnt that they won't conduct at all and the relay will have to be replaced. If you could get a Chilton Service Manual for the Vehicle in question it would probably show the exact location of the relay.
Sep 02, 2009 | 1998 Nissan Quest
1995 Chevy Astro Van, Power windows that only work intermittently, sometimes a few inches and sometimes less before stopping altogether. Both windows, one side has almost stopped completely. I have taken...
try to check wiring in door hinge area for cracks and brakes otherwise get some "lectro-motive" spray and spray the motors BEFORE you replace the motors
Aug 23, 2009 | 1995 Chevrolet Astro
Electric door locks not working from driver's door master control
probably is the switch going bad sounds like it needs replacement.
May 20, 2009 | 2001 Hyundai Elantra
1995 RS Drivers WIndow does not function
use a test light , remove the door panel , unplug the wires going into the regulator motor . . check the the plug with the switch to see if you are getting power and ground .if you do , than it will be the motor. Before you do that , check all fuses , some have a fuse for the left side , and one for the right side windows .
Jul 20, 2008 | 1995 Acura Integra Coupe
Gateway Ne56r31u Intel Celeron B830 X2 1.8GHz 4Gb 320Gb Dvd /- Logo
104 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
