Question about Akasa integral P2N black, USB 2.0 AK-ENP2N-BK
Beeoing noise and wont connect to television
Put the usb cable in and switched on the tv and hard drive, the drive makes a beeping noise and wont connect to the tv
The tv usb is not able to read all drives....drive size and formats are different per tv maker..
secondly you need to supply external power to the.... tv usb connection do not supply enough power(usually only 500ma) to run hard drives
Posted on Nov 17, 2013
Beeping noise when connected to tv
Beeping often indicates a power problem. Try a different usb cable.
Sep 04, 2012 | Iomega 500GB Prestige USB 2.0 Portable...
Hp md1000h has a blinking blue light
The drive is bad. Try it on a different usb port. Try it on another computer. If it can't be recognized, it's bad.
Jun 02, 2012 | HP SimpleSave 1 TB USB 20 Hard Drive
Hello, my seagate external drive is not registering on my mac but is making a beeping noise. What does this mean?
Try changing your USB cable you are using to connect the External drive.. It may be that the usb cable is not good and thus the Drive is making beeping sound..
If it helped you please say thanks and like/rate the comment please
Jun 06, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a 1 TB SimpleDrive external USB drive. The drive is now making a repeating, beeping noise, slow and methodical, and it is not recognized by either my MAC or my pc. WHat does the beep-beep-beep mean...
the beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM is securely seated,
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
when you plugged the external disk drive you got that windows could recognize the USB device change the cable just replace the cable of the hard disk everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Apr 30, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
Maxtor 320 GB mini not working
If it shows up as a USB mass storage device it:-
1. Has power
2. It is connected to the computer via USB.
3.The correct software has been loaded for the hard drive.
The beep sound is probably an error message saying that the drive is not responding properly inside the case.
Hard drives Drives have been known to stick or not start up due to power cables or ribbon cables being dislodged. Try pushing these back into place.
If this is not the problem go to the Maxtor site (maxtor.com) and report the problem with the drive, not the USB which appears to functioning correctly.
Mar 07, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
Wont show anything
Try to restore your ps3 system in the recovery menu.
Here is how.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Hope this will help you.
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
Maxtor One Touch 4 is beeping when I connect it by usb
Is this a new drive or have you been using it for some time and it just started doing this? What make/model computer do you have?
Usually when they start beeping like that, it's an indication that the drive is not getting enough power. It's possible that you are plugging into unpowered USB ports. Try using the USB ports that are directly connected to the motherboard (the ones in the back.)
Use USB 2.x ports if they are available. Try connecting the drive to another computer.
Jan 28, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Broken portable hard drive - Maxtor (750)
I HAVE A RECOVERY UNIT IN MUMBAI INDIA . YOU CAN GET MY EMAIL ADDRESS FROM THIS SITE .. WE CAN BEGIN FROM THERE AS THERE IS A HARD DISK DAMAGE WHICH HAS TO BE RECTIFIED
Jun 13, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Seagate freeagent 500g usb 2.0 beeps sound
I am so happy to say that i HAD the exact same problem.
Its an issue with the drive disk itself. Long story short because i dropped the drive the the disk was no longer able to spin fast enough to start the drive (the beeping sound actually being the disk trying to start spinning.
After spending literally the last 4-5 hours looking for a solution I found a unusual method that basically either works, or it doesn't there's no it kind of works. what you need to do is unplug the drive, then plug it back in and start Vigorously spinning it whilst keeping the drive horizontal (similar to what you would do when your unscrewing a light bulb).
You have to try and do so simultaneously with the beep and it should "kick start" the drive (AND OBVIOUSLY DON'T LET THE WIRE DROP OUT AS YOUR SPINNING IT AS YOUR COMPUTER WONT RECOGNISE IT IF ITS NOT PLUGGED IN).
I Know this method sounds far fetched but put it this way, 15mins ago I was working out how im gonna get hundreds of pounds to restore this drive, Now, i've just finished copying my informations onto a laptop from the drive so i can take this piece of plastic **** back to the shop :D.......
Never again Seagate and Thank God for letting me find a solution.
Feb 11, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Akasa integral P2N black, USB 2.0 AK-ENP2N-BK Logo
73 people viewed this question
Top Akasa Computers & Internet Experts
David Payne
David Payne
Are you an Akasa Computer and Internet Expert? Answer questions, earn points and help others
