Question about Plumbing
Elkay ezfs8 How do you stop the water from running constantly . I have the water inlet valve turned off now
  • 2,113 Answers
Turn off the shut-offs unscrew the handles and remove. Remove the valve stems (sometimes there is an escutcheon or collar to remove first). Using the handle to hold the valve stem use a screwdriver to undo the screw holding the rubber seal. Replace the seal. Verify with the screwdriver that the valve seat has no channels worn into it. If it does either remove it with a seat wrench and sand it by rubbing it back and forth on a piece of sandpaper, or by replacing it. Reassemble. Turn on your shut-offs and test the faucet. Remove and clean the aerator (this is done every time you do plumbing work)
Posted on Nov 19, 2013
Water from Elkay wall mount water cooler is coming out cloudy. I know it has air in system and i let water run for over 5 mins but water remains cloudy. Looing for solution
  • Check the water shut off valve is not open all of the way if not open shut off valve all of the way.
  • Check to see if the regulator / control valve is restricted with debris or not working properly. If so clean debris or replace the control valve.
  • Check the water inlet screen is for debris, clean or replace screen
  • If there is an external water filter, check to make sure it is not clogged.Check the income water line, if flexible, to make sure it is not kinked, is it is rework it to remove the kink.
    Dec 06, 2012 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    Water flows constantly during the spin cycle
    Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced.
    Dec 08, 2011 | GE WBVH6240F Front Load Washer
    Elkay drinking fountain M#erpb28c continuously runs, having problems getting mounting nut back onto bubbler, seems basin should come off for access, however needind a reapir manual or access instructions...
    The Elkay fountains are turned on by a solenoid powered valve. There is a rubber grommet in that valve assembly that gets holes in it and then water gets behind it, causing the valve to stick on. To test that it is a solenoid problem, turn the water on and then unplug the power to the fountain--if the water continues to run you have a solenoid problem. You'll need to replace the solenoid and I've detailed how to do it with all the steps and lots of pictures on my blog: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
    Feb 22, 2011 | Vacuums
    Water continues to run into the washing machine through the whole wash cycle and even when the machine is off. I have to keep the tape turned off. other than that the washing machine functions normally.
    Hi Welcome to FixYa I am Kelly. You have debris inside your water inlet valve. You can try to clean it by doing the following:
    - First remove both hoses from the water inlet valve and remove the inlet screens of the water valve.
    (Use a knife blade on the outer part of the screens to remove them from the water valve)
    - Connect both hoses to the water inlet valve without the inlet screens.
    - Connect ONE hose to the wall faucet
    - Place ONE hose in a bucket
    SELECT WARM WASH and start wash fill
    Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your trying to free the debris from the inlet water valve diaphram)
    Stop Fill
    Reverse Hose connection at the wall.... i.e. hook up other hose and disconnect the one you had connected. Place the hose you disconnected from the wall into the bucket.
    START warm fill
    Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your STILL trying to free the debris from the inlet water valve diaphrams)
    STOP FILL
    - Connect hose to wall connection
    - WASH the inlet screens under slowly running water until both sides are clean
    - Remove hoses from the water inlet valve and install the inlet screens.
    - Reconnect hoses and turn on water supply
    TEST HOT and COLD fill
    Turn off machine.... IF the debris was freed the water flow will stop when the machine is turned off.
    If this flushing attempt does not correct your constant water flow the remedy is to replace the water inlet valve on your washer.
    I can help with locating parts ON-Line but will need your model number to help you should you require a water valve.
    Hopefully you are able to clear the debris by doing the above. (50 - 50 chance of it working)
    Thanks for Choosing FixYa,
    Kelly
    Dec 17, 2010 | Washing Machines
    How can adjust the volume of water coming from the drinking spout on my Elkay water fountain?
    On our Elkay drinking fountain there is a set screw underneath that you can turn to adjust the flow rate. I have detailed how to adjust the flow along with how to replace the solenoid on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
    Mar 19, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
    The water dispenser in the door of my ge refridgerator constantly is running water, like it is stuck on. We had to shut off the valve to stop the flow. Any suggestions?
    HI, This will be the result of a failed water inlet valve. There may be debris present in the structure of the valve, that is preventing the valve from closing, correctly. This is know as mechanical failure. This will require you to replace the valve, asap.
    The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source. Disconnect the supply line. Remove the screws that secure the inlet valve in place, and replace the valve.
    Dec 28, 2009 | GE Refrigerators
    Water pressure is low on the elkay fountain
    if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
    Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
    Constant running of water
    You need a new water inlet valve. this will fix it.
    Jan 23, 2009 | GE WBSR3140DW Top Load Washer
    Plumbing Logo
    103 people viewed this question
    Top Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
