Question about Wildon Home Elsie Twin/Futon Bunk Bed in Black"
Install directions - Wildon Home Elsie Twin/Futon Bunk Bed in Black"
Burnout Paradise The Ultimate Box's Installation is still installing Direct X 9 on my PC and it's been ONE HOUR. Did the installer freeze or something ?
Yes it did freeze try reinstalling the game it will fix that in most cases or you can directly download Direct X 9 and install it separately.
Aug 10, 2013 | Video Game Consoles & Games
Lost the disk to install a HP C4480
You can get install software directly from http://www.hp.com/#Support for free. Follow the directions exactly, often you are NOT to plug the printer in until software is installed and directs printer connection.
Dec 25, 2010 | HP Office Equipment & Supplies
Hello how to enable direct x features please help me
Hi, its pretty simple. All you need to do is to install Direct x 11 and just type "dxdiag" and here you can see the version and other related details. Just need a compatible graphics card to ensure the functions are operational.. Same i have did just by downloading the DX 11, though Microsoft's official was little confusing about the download so i have outsourced it from DirectX 11 DirectX 11 Free Download For Windows WebForPC
Mar 08, 2010 | Ubi Soft Entertainment 02B Game PC...
Hi, I bought an Inspiron E1405 Media Center Edition in '06 and it never really worked properly. I was never able to use the "media direct" button or any of the other feats. I thought came with? On top of...
Since XP was reinstalled and the HDD was not prepped with the Media Direct CD before XP install Media direct will not work. You can purchase a Dell Media Center CD on ebay for about $20
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Dell+XP+Media+Center+Edition&_sacat=See-All-Categories
I also found a Media Direct CD for a Newer Model, so I'm not sure it would work on yours. Media Direct requires that the HDD be formatted with Media Direct and then the XP installation, Driveras and applications, then install of Media Direct SW. Once done in that manner, you should be able to boot to Media Direct to play a DVD (To be honest, I never found the Media Direct function that useful)
Oct 20, 2009 | Dell Inspiron E1405 Notebook
It says i need direct x 5
install directx 9c to play this......
Aug 16, 2009 | Fox Interactive Croc 2 for Windows
Direct X 9.0 c Cant be installed
To determine what version of direct x you have installed, click on START- RUN then type in the word :"dxdiag" in the run window. This will bring up a direct x diagnostics tool which will display the direct x version near the bottom of the page.
Determine which version you have to narrow down the possible errors on your system and games.
Regards,
Graemevm
Apr 22, 2009 | ATI PowerColor R92P-C3S RADEON 9200SE PCI...
Media Direct problem
This is a known problem my friend... The Dell Media Direct Software requires a different partition to work (except version 4.0) so here is what you need to do... You need to boot using the Dell Media Direct Disk n let it create a partition for itself... then go about reinstalling your OS n then once the OS is installed then pop the Dell Media Direct disk back in again n complete the installation....
Hope this answers your query :-)
Feb 12, 2009 | Dell XPS M1210 Notebook
Dell media direct won't work
Here is the steps,
1.Turn on your computer.
2.Insert the reinstallation media (Dell Media Direct CD/DVD) into the CD/DVD drive, then restart the computer.
3. press F12 when the bios page comes up and then select CD/DVD drive from the boot menu.
"Option 1" from the menu if you wish to use all of the hard drive for you operating system installation. This is the most common selection and how is your computer was originally shipped to you, unless you specified an operating system partition size at the time you ordered you computer.
"Option 2" to designate a size for your operating system and have a data partition. This allows you to specify a size for the operating system partittion, leaving the remainder, of the hard drive configured as a "data" partition ("D")
4. Once you have prepared the drive and you have returned to the main recovery menu, remove the installation media and replace it with you operating system reinstallation media. Select the option to reboot your computer. If your computer does not automatically start the media, press <F12> to access the boot menu and select the Cd/DVD boot option.
5.Install your operating system, select the Primary partition when prompted. If you have two hard drives, select the primary partition on the same disk where hte media direct partition resides. Once the OS is installed and the necessary drivers are installed you can begin the reinstallation of the dell mediaDirect software.
Good Luck,
Austin
Feb 12, 2009 | IBM ThinkPad T30 2366 Notebook
Media Direct Problem witn more then 2 disk paritons.
Usually Media Direct is pre-installed on a Dell Portable System. It is installed on a media direct partition. If you reinstalled windows and if you formatted yor hard drive then you may have to reinstall media direct in 2 different ways.
Media direct 2 requires to have windows installed first.
Media direct 3 requires to have the Media Direct CD run first.
Feb 06, 2009 | Dell XPS M1530 Notebook
Hi!how can i upgrade direct X p.0b to direct X 9.0c?
http://www.microsoft.com/downloads/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
have you tried 2 download from there? dl that and after double click on the .exe file then will start updating your current directx
Feb 01, 2009 | Microsoft Windows XP Professional With...
Wildon Home Elsie Twin/Futon Bunk Bed in Black" Logo
48 people viewed this question
Top Wildon Home Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Wildon Home Furniture Expert? Answer questions, earn points and help others
