Question about Juki DDL-8300
Please help me how to thread my juki dia rotary 7...can you please give me a diagram of how to put thread...your help well very appreciated...tnx khen
  • 5 Answers
SOURCE: threading juki DDL-227 machine
There is a free download threading diagram for the DDL-227 here:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
Posted on Mar 23, 2009
yalmer
  • 549 Answers
SOURCE: threading a juki ddl 5530
Go to this link and you will find how to thread your machine.
Posted on Apr 02, 2008
Zenqi
  • 208 Answers
SOURCE: THREADING FOR JUKI MO 357
Put new needles in it.
Following the colors, thread the upper looper first, then the lower looper. Next thread the needles. Always thread in this order.
Posted on Jun 27, 2009
SOURCE: I have a Juki MO 3716 and I cannot thread it. Please help. It has four threads.
I also own a Juki MO3716. It is a five thread not a four as it has three lower looper threads. Two are fed through the front, just follow the color codes and the threading diagram on inside plate that you lower to see the threads, the third is threaded through the back and around the left side. I can send email with picture of diagram if needed. the other two threads are for the two top needles. This machine is a true safty stitch with the overedge row of serging and an inner chain stitch row for secure seaming. You can run this machine quite nicely with only three thread ( one inside needle and the two front loopers. If you need further held email me at wanmacinnes@eastlink.ca
Posted on Jul 16, 2009
Zenqi
  • 208 Answers
SOURCE: which way to put the needle in the Juki, The
The indent is called the scarf.
The scarf will be at the 3 o'clock position and, if you look closely, you will see the hook pass the needle at the scarf.
Posted on Oct 01, 2009
How to thread a Juki 2512 3 thread
Perhaps this will help:
Juki MO 2504 2514 2516 Sewing Machine Threading Diagram
there are usually multiple web sites and videos available. Just search for:
Make + Model + the words "Manual" or "threading"
Sep 30, 2016 | Juki Sewing Machines
How to thread a Juki MO 816 DD6 industrial serger, please.
Did you get a book with it? If not, buy or access one online.
Copy the threading diagram from the book:.
1. Blow diagram up to full page size on the copy machine.
2.Make as many copies as the # of threads you are going to use (3 threads=3 copies, 5 threads=5 copies etc.)
3.Buy as many colors of magic marker as the number of threads you are using. (Or borrow from your kids, the neighbors or use crayons)
4.On copy #1, using the original threading diagram, use one color of magic marker to follow the thread through its patch from the thread cone to the needle.
5.Do the same with each of the other copies: Copy #2=thread #2, Copy #3=thread #3, etc.
6.Now you should have a page for each thread as it comes off the cone.
7.Use a thread color that corresponds to the magic marker color on your page to make it clearer. After it is threaded properly, you can tie the color you plan to use and pull them through.
By using different color threads, and a good light, it is easier to see if you have missed a place or crossed a couple thread improperly.
If all else fails, try to find someone else who knows how to do it to thread it for you, then take a couple close up pictures of the inside of the machine with it threaded properly, take them to the photo shop and have a copy made to keep with your machine to refer to in the future. Good Luck! Sergers are their own nightmare to thread but once you get it down, you will be fine and love it. Juki is one of the easiest of the bunch. If you have a pair of tweezers and a couple threading wires, it sometimes helps!
Jun 25, 2016 | Juki Sewing Machines
Need beginners manuel for 1541-s Industrial Sewing Machine
Contact your seller or Juki and ask for a threading diagram.
Sep 01, 2012 | Juki Sewing Machines
How solve Juki DDL 8700 automatic single needle machine E-7 error?
hi there,
1- check V belt if there's more loose plase make it tight littel.
2- check timming cam for thread trimmer , sometimes lock after trim and E7 appear.
please advice me type for control box ? i can give more help if you have basic knowledge for electronc. just email me if you want any time.
best regards
ashraf abozid
aabozid@hotmail.com
CAIRO - EGYPT
Jul 28, 2011 | Juki DDL-8700
My Juki 8700-7 top thread springs back through the needle after trimming. any help would be greatly appreciated
hi there
please check timing cam for thread trimmer, need to re adjust again - check tension disk is open during trim or still close ( if closed always please check some parts missing from tension ) - check wire between tension and solenoid trimmer correct or no movement.
best regards
ASHRAF ABOZID
CAIRO - EGYPT
Mar 29, 2011 | Juki DDL-8700
May 23, 2009 | Juki Sewing Machines
Thread looping underneath quilt
Your problem is the top thread. Make sure you lift the presser lever BEFORE you thread the machine. After threading the machine, just before you thread the needle, lower the presser foot, and test the top tension by pulling down on the thead. If there is little or no tension, adjust the top tension to a higher number, say from 3 to 5, or from 5 to 7, and test the tension again. If you fail to increase the tension by above procedure, look for cotton that might be stuck in the tension blades and remove it. Hope this will help you
Nov 11, 2008 | Juki TL-98Q
Threading a juki ddl 5530
Apr 02, 2008 | Juki MO-644D Mechanical Sewing Machine
Juki DDL-8300 Logo
175 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
