Question about Sanyo Televison & Video
How to Unlock SANYO LCD 24K40 with out a remote control.
5 Suggested Answers
  • 20 Answers
SOURCE: We just had a lightning storm come through which
I've checked on line for a schematic of this TV but was unsuccessful but I suspect it is one of two problems.
1) A fuse inside the TV was blown from a power surge caused by the storm. If you can locate it pull it out and look to see if it looks blackened (even a little) or if the wire inside is broken. This would indicate the fuse did it's job and stopped the power from burning out the whole TV. All of these fuses are available at your local electronics store or Radio Shack if you have one nearby.
2) The power supply on the TV was hit by the surge and burned out. There is no simple solution to this problem as the power supply would need to be replaced and the only way to do this is to hire a qualified TV repair service. If you happen to be good at soldering and understand electronics you could do this yourself after buying the power supply on line. I checked online and the part is about $60-70 USD.
There is a possibility that the power surge could have fried one of the circuit boards and if that's the case then you would have to weigh how much you want to pay to repair the unit after having a repair service estimate the work. I feel pretty strongly that you have one of the other two issues I listed since you didn't mention any other items in your home that were damaged at the same time. If there were more items then I would suspect the power surge would have been much more massive and likely caused considerable damage but since not then the damage would be minor leading to my previous conclusion.
Posted on May 23, 2011
SuperTech-11
  • 1591 Answers
SOURCE: I have both lost my
Most TVs will have a "Press for 5-10 seconds" unlock function.
Usually it's holding the power button that unlocks it, but if that doesn't work, try all the other panel buttons in the same manner.
Posted on Jun 18, 2011
danbusa
  • 185 Answers
SOURCE: Programming my remote control (which is a dish
In order to program the remote to a TV set, hold the clear "TV" button in the upper left hand corner four four seconds or until all four of the mode buttons light. Next press in one of the three digit codes below followed by pound (#) Remote codes: 590, 683, 720, 591, 543, 593, 813, 542, 533, 652, 726, 611, 500, 503, 627, 661, 956, 591, 694, 666, 252 After trying each code press the volume and power buttons, if they control your TV set be sure to press the "SAT" button.
Daniel Busa
DISH Network
Customer Service
Posted on Sep 01, 2011
SOURCE: how to reset the TV
Hold down "INPUT" Button at TV panel, while you press "INFO/A-B" button in your remote.. Or...Hold down "INPUT" Button at TV panel, while you press No.1 chnl on your remote..
Posted on Dec 14, 2011
How I unlock my Sanyo lcd 24k40 .i also lost my remote
If you wish to get some details; check the site linked here. Pull up older posts.
Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Sep 01, 2016 | Sanyo Televison & Video
SANYO LCD 24K40 TV instead of Red or Green the power indicator display Amber color
press the helpful button,
the amber light may be for stand by or sleep mode, go into your tv setup and check that these are turned off
Jan 12, 2016 | Sanyo Televison & Video
TV shows on left side: 24" LED-TV / HDMI. after a few seconds flips to other side of TV and says: Sanyo supplying high quality TVs in the U.S.for 35 years. how do I stop this?
Hey,
This might be due to a mode selection.
LCDs usually comes with "Home" mode and "Shop" mode. The "Shop" mode is usually used for retailers to display the product.
Possible Solution
Go to Setup by pressing the "Menu" key on the remote control.
Try finding some terms that equivalent to "reset".
BEWARE:
1) This will reset all settings that you have recorded
Channels, programmers and the whole shebang
Please retain all current settings first before reset procedure.
atb
Aug 18, 2015 | Sanyo 24K40 24 inch Multi-System LCD HDTV
Locked accidentally. How can I unlock it?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Jul 23, 2015 | Sanyo 24K40 24 inch Multi-System LCD HDTV
Sanyo lcd 24k40 locked now. Have not remote. How can restart doing? please...
Without a remote control, you can't unlock it. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name" of your device, in the search box [at the top right] of the display window to get gathered all the related posts to this brand devices. It will make surf easy.
Jul 09, 2015 | Sanyo Televison & Video
HOW DO I REMOVE CHILD LOCK ON A SANYO TV 24K40 MODEL WITHOUT REMOTE CONTROL
Unfortunately unless you can access the settings menu from the TV buttons you will need the remote control!
Jan 30, 2015 | Televison & Video
How can I unlock my Sanyo TV set
Without its remote control; you can't unlock it.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Gopakumar Gopalan Google
Aug 06, 2014 | Sanyo LCD-24K40 MULTISYSTEM 24 INCH LCD TV...
How to reset the TV menu on my sanyo vizon 24k40?i think a menu pop out and someone in the house mess it up?can't access the whole menu and remote control isn't working?
Sep 04, 2011 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
I have both lost my remote and activated the child lock on my Sanyo LCD-24K40. How do I deactivate the lock without the remote?
Jun 18, 2011 | Televison & Video
Televison & Video Logo
228 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
