Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Need to replace direct drive drum on Kitchenaid Superba side by side
The blades of the drum in the ice tray broke so I ordered a replacement kit. I have taken the ice dispenser apart but do not know how to get the auger shaft pulled out so that I can replace the drum. Their is a plastic piece at the end and I can see the end of the auger sticking out, but cannot get anything to unscrew. The teeth of the ice crusher are being held in. Any idea on how to remove the auger shaft so that I can replace the drum?
  • 1 more comment
  • B Weed Oct 13, 2007
    The model number is KSRS25FGSS13 and it was a reverse thread so I was able to get it taken apart and get the drum replaced.  However, I must not have assembled the arm control and spring return correct as it will not spring correctly for crushed ice.  Can you assist me with how the spring and arm control should be set?  The parts I'm referring to are AP2966474 and AP2936516 if that is helpful.
    Thanks
    Brian
    I will try the appliance store.  Thanks for your assistance.
  • Anonymous Mar 13, 2014
    I have a stikemaster 137 ice auger that will not start it kicks but will not run. when it tries to start gas leaks from the muffler. I rebuilt carb and did compression test held @ 125. what do you think it could be and can you point me in that direction
  • 473 Answers
May need to know your entire model # located on the inside in the refrigerator section. That plastic piece may unscrew but be a reverse thread.
Posted on Oct 07, 2007
  • Craig Shelton
    Craig Shelton Oct 13, 2007
    I know what you are talking about but I don't think I could possibly describe how to do it in writing.  I would go to an appliance store and look at a fridge similar to yours and see how it goes together.  Hope this helps.
SOURCE:
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba the ice maker not filling up and making ice
dear owittione perhaps the tray if its plastic maybe its cracked and the water drains out while filling check to see if there is a clump of ice in the bin and if so replace the ice tray no if is metal maybe the same thing is happening also check for the clump of ice in the bin. Now if you dont hear any water going in the ice tray maybe the magnetic valve in the back of the fridge is bunded out or the hose from the tap to the valves has a leak or the hose from the valve to the ice tray has a leak . Check around for water puddles if formed. Those are the probable causes that can lead to your problem ofcourse if the refrigerator over all is working fine. good luck. Regards Tony.
Dec 02, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba ice maker not working. Any ideas?
i HAVE REPLACED THE MICROCPTR, 046.106.4389102 PER EARLIER DIRECTION. THE ICE MAKER STILL DOES NOT WORK
Jun 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Chute door dislodged
IF THE ICE DOOR HAS COME OFF, THE CHANCES ARE THAT THE PLASTIC TAB THAT HOLDS THE HINGE PIN IN PLACE HAS BROKEN. IT IS PART OF THE PLASTIC HOUSING. WHIRLPOOL/KITCHENAID HAS A FIX KIT THAT REPLACES THE PLASTIC TABS WITH A METAL BRACE THAT IS PRESSURE TAPED IN PLACE. I HAVE INSTALLED A COUPLE OF THESE KITS AND IT TAKES PATIENCE AND TIME. THE KIT WILL HAVE INSTRUCTIONS ON HOW TO INSTALL. FIRST VERIFY THAT THE TAB HAS BROKEN. IT IS LOCATED IN THE UPPER LEFT SIDE OF THE OPENING TO THE ICE CHUTE.
Mar 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba KSRG22FKSS01 Ice cube switch trouble
Since its an indoor ice maker its much harder to diagnose. However the motor is supposed to reverse for crushed/cubed so you can hold the freezer door switch and see if it does. If it doesnt reverse it could be the switch, or it could be a mechanical problem inside the blades (check for broken stationary blades)
Oct 18, 2007 | KitchenAid KSRS25IL Side by Side...
Ice maker on side by side
Spray your ice maker tray with pam. Ice maker trays build ups from water so occasionally spray them with pam and they will dump okay.
Jul 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kithcenaid Superba KSRS25QDWH01
If you pop the front cover off the ice maker you will find a screw with a plus and minus on it. Adjust it and that will cut the water fill down and should solve the overfill problem.If the ice is not dumping spray the tray with Pam and that should solve the dump problem.
May 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
157 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
