Question about Cell Phones
NOKIA E7 mobile is hanged and do not any work only switch off and on is done
    Sergeant:
    Champion:
  • 223 Answers
Hi this will perform a factory reset of your phone but be warned you will lose EVERYTHING. Press volume down camera key menu key and power button and hopefully your phone will boot up properly again. This should only be used as a last resort
Posted on Nov 17, 2013
2 Suggested Answers
  • 96 Answers
SOURCE: how to open the battery casing of E7 Nokia.
Hi.. Just check out this following link http://www.youtube.com/watch?v=LNCwCHl0Uk0
Posted on Dec 12, 2011
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
Mar 23, 2014 | Nokia E7 (16 GB) Smartphone
Reset password
  5. The process will do format to factory default Nokia E7.
Source: http://www.hard-reset.org/factory-default/how-to-easy-master-format-nokia-e7-with-safe-hard-reset/
Jan 15, 2014 | Nokia E7 (16 GB) Smartphone
Nokia e 7 hanging and turning on and off
Try by removing your SD card (Memory card) and see whether it's working or not?
If it happen the same issue.
Then your OS (Operating System) has been corrupted.
So please refer to the nearest mobile service for FLASHING
Thanks for using FixYa!
Oct 16, 2012 | Nokia E7 (16 GB) Smartphone
I WANT TO RESET MY NOKIA E7-00 WITHOUT ENTERING SECURITY CODE
You Can Hard Flash Your Nokia E7-00 without Security Code. At First Switch off Your Mobile, Then Press And Hold Green Key+End Key+Camera Key And Press Power on Button or see Complete Format Nokia Mobile Without Security Code.
Feb 18, 2012 | Nokia 3110 Cell Phones
My E7 get hanged ,its not starting now.
I had the same problem with my E7, it just wouldn't switch on, if you've already tried holding the power button down for 10 seconds then you'll need to remove and replace the battery, that fixed mine straight away. Just follow the guide below
Aug 29, 2011 | Nokia E7 (16 GB) Smartphone
How to umlock nokia e7?
Hi,you can try unlock codes from your provider or can get it from online providers..once i got unlock code for your mobile from classicunlocking and got my mobile unlocked..you can too getting codes from them and get your mobile unlocked...but before that check whether unlock codes are available for your country and provider...
Aug 12, 2011 | Nokia E7 (16 GB) Smartphone
My nokia e7 gets hanged since yesterday...i cannot open the battery coz its under warrantee... so what do i do...
If the phone hangs then please take it to a service center and get it serviced there... even after the service if it hangs, then fight for a replacement.... Because Nokia N8 and E7 series comes with replacement warranty if you are not satisfied with it...
May 23, 2011 | Cell Phones
Two days back my cell nokia E7 fell into water and was there in it for 5 minutes.Intially it started after a while when we kept in sun n made it dry but later on it got switched off and till now its not...
First: Do this before:
Remove the battery and sim
Then DRY it with warm air (hair dryer) for 5 to 10 minuetes or more
but keep the dryer far of the phone in case it becomes too hot and be damaged.
keep do this till it turns on
IF it doesnt work, Find A MOBILE REPAIR STORE.
May 19, 2011 | Nokia E7 (16 GB) Smartphone
Cell Phones Logo
52 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
