Question about Garmin 185 Sounder GPS Receiver
Replace garmin 185 battery - Garmin 185 Sounder GPS Receiver
Garmingps185 low battery how to replace battery
Panasonic BR2032 Battery has solder tabs soldered to pads on PCB, no need to even remove it. Simply remove the back and get out your trusty solder iron.
May 04, 2012 | Garmin 185 Sounder GPS Receiver
It does not alert me of traffic jams
¹Lifetime traffic extends for the useful life of your Garmin traffic receiver (as long as you own a compatible Garmin GPS) or (READ THIS---)----> as long as Garmin receives traffic data from its traffic supplier, whichever is shorter. (AND THIS------>Traffic content not available for all areas. See http://www.navteq.com/rdstraffic for traffic coverage areas and www.garmin.com/traffic/fm/navteq.html for program License Agreement containing complete terms and conditions.
Sounds like either the system is not getting the updates or else the updates are not being provided, but either way something is not happening someplace. Or maybe you have the traffic system shut off because it was annoying you one day.
Hope this helps
Jun 26, 2011 | Garmin nuvi 1490T GPS Receiver
Our Garmin 185 is not reading the right position. We are in New Zealand and we should be south and east but is reading north and east and dont seem to be able to change it.
Most GPS units require 3 satellites minimum to tri-angulate your positon (more is better but 3 is minimum). From the question your asking I would think the unit needs to be sent in for repairs because it is not positioning your correctly only garmin can make those repairs for you that I am aware of. Garmins website is www.garmin.com Go to the top of the screen to the right you will see My garmin there. Click on that and send them an email or call them on how to get your unit repaired.
I hope this helps you out, and any positive feedback on here would be appreciated.
Apr 04, 2011 | Garmin 185 Sounder GPS Receiver
I bought the Nuvi 1490 which should have come with live traffic. It has never worked and I can't add it to my GPS
This is from Garmin's website, www.garmin.com, regarding the Nuvi 1490T. If you haven't already done so, you might want to check and make sure you are in an area that does receive traffic coverage.
¹Lifetime traffic extends for the useful life of your Garmin traffic receiver (as long as you own a compatible Garmin GPS) or as long as Garmin receives traffic data from its traffic supplier, whichever is shorter. Traffic content not available for all areas. See www.navteq.com/rdstraffic for traffic coverage areas and www.garmin.com/traffic/fm/navteq.html for program License Agreement containing complete terms and conditions.
Jul 17, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
Battery on my garmin c510 sat nan wount hold a charge how easy is it to change
Had the same problem. Fixed with a new battery. Takes the same as a Streetpilot c530 and can be purchased anywhere on line. A 10 minute job with a soldering iron.
1. Open face plate. Unscrew 4 screws. Remove battery connector and clip.
2. Unsolder the wires to the two speakers - 4 wires.
3. Remove the sticky wrap from the old battery and place around the new one (to stop it rattling).
4. Solder back the new speaker wires.
5. Plug in battery, reassemble unit and charge Garmin off PC wih usb cable.
Done!
Sep 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Replacement of the memory battery of my Garmin 195
Piece of cake. Remove screws from back of device. Separate the housing and carefully lift up circuit card off of pins. There is a battery holder underneath. Simply remove wafer battery and replace with like model battery. Put back together and you're off.
Jun 13, 2009 | Garmin 185 Sounder GPS Receiver
Remove and replace the lithium coin batt from a Garmin gpsmap185
The battery is a Panasonic BR2032-1F2; the suffix desinates that it has two flat tabs for soldering into the unit horizontally. Once you remove tha back of the unit, you'll see the battery next to a resistor that's siliconed in place. You'll need to knife the silicone loose so you can gently move the resistor aside to reach the soldered tab underneath it. Just heat the solder on each tab with a small soldering iron until it melts and the tab pops loose.
Install the new battery with the unmarked side up (the other side has type) and solder in place. Reinstall the power and antenna connections in the cover, replace the cover, power up the unit and start re-creating all your lost waypoints.
Batteries can be ordered online from Allied Electronics at $2.42ea (www.alliedelec.com)
blackcatjim
Mar 21, 2009 | Garmin 185 Sounder GPS Receiver
NO DEPTH READING
Check the finder on the bottom of the boat and make sure the cable is ok?
Aug 09, 2007 | Garmin 185 Sounder GPS Receiver
Garmin 185 Sounder GPS Receiver Logo
51 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
