Question about Canon PowerShot SD1100 IS Digital Camera
Beach dust dropped in beach.
Lense covered in mist and cannot turn on
  • 35 Answers
Cameras and beaches don\'t do well at all. The most important thing is to remove as much sand as possible without scratching any part of the camera. I\'d suggest to not wipe it at all, but take it home and try to vacuum the sand and dust off. It can get wedged in the drive mechanism for the lens focusing and will stop the camera from going through its normal initialization cycle. Check around the edges of where the lens moves in and out for sand, and try to suck it out.
Posted on Nov 17, 2013
St 105
possible dust, or sand if you were on the beach on a windy day, blow out with hair dryer set on cool or cold setting, don't use it on warm or hot setting, you can also try and push it in gentle when you turn the camera of, I did this with the wife's camera and she hasent had any trouble since that was a year ago, if you think it is to risky then take it to be repaired, don't force it to hard. hope this helps.
Apr 29, 2014 | Samsung Cameras
Need user manual for hamilton beach true air 05518 humidifier.
Your Use and Care Manual for the Hamilton Beach Cool Mist 05518 Humidifier can be found here:
http://useandcares.hamiltonbeach.com/files/840115700.pdf
Thank you for using FixYa!
Aug 13, 2011 | Hamilton Beach Cool Mist 05518 Humidifier
Nikon Coolpix 4600. Lense cover does not close when camera is turned off or fully open when camera is turned on. I can move it all the way open with my fingernail. Seems like mechanical mechanism is...
Any sand in a compact camera is bad news - repair will be expensive. In your situation, I would continue to use the camera while it still works, and give serious thought to a replacement.
Jul 20, 2017 | Nikon Coolpix 4600 Digital Camera
When I power on the lense cover only partially opens and will not close when I turn the camera off. Sony DSC-P52
The problem could be from simple dust accumulation to a camera drop. If you take it to the service center, it would be an easy fix, and won't cost you much.
Feb 14, 2010 | Sony Cyber-Shot DSC-P52 Digital Camera
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Turn the power off and on again
Jun 25, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Lens keep extended in an out
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
I have the same problem
Hi:
If you did not drop it, you probably have some dust or small particles around the outside of the lense. They prevent the lense from fully opening. The lense cover might have the same problem. As a result it is stuck.
When the lense open up try to clean around the lenseor the cover. If it opens, but not all the way out, try to pull it out NOT too hard.
When it opens, try dust off. Make sure you do not force too hard on all of the steps above.
Good LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 23, 2009 | Samsung Digimax S630 Digital Camera
Nikkor Lens Fix
The fading (flare) you see could simply be a finger smudge or other stuff. One little scratch won't do it, you'd have to take sandpaper to the lens to see obvious flare.
It's actually harder to scratch a modern lens than most people think. When it happens, it's usually during cleaning when a tiny piece of grit is on the surface and gets rubbed in by the cleaning cloth/lens tissue.
So the first step in cleaning a lens surface is to be sure you remove all dust and dirt without rubbing. The lens cleaning kit you can find in any camera store is a start -- it contains a blower brush. With the lens surface to be cleaned facing down (so dust falls away), brush gently with the tips of the bristles to dislodge stuff. Then use the blower to blow it away. Repeat as needed.
If you still see dust and dirt which seems to be stuck on the surface, take a piece of the lens tissue from the kit and put several drops of the cleaning solution on it, enough to get it pretty damp. (Always apply cleaning solution to the tissue or cloth, never drop directly on the lens surface.) Cover the lens surface with the damp tissue, pressing it into the corners, but do not slide the tissue across the surface. Just lift it away. Repeat with another section of tissue.
Then take a full sheet, wad it lightly, and wet it. You are going to rub lightly, using a roll-up motion as you move the tissue so that dust/dirt is lifted away from the surface and fresh tissue is always coming in contact with the surface. Repeat as needed until there isn't any visible stuff.
Final cleaning can be done with a fresh piece of tissue and a bit of mist from your breath. Mist the surface, and lightly polish with the tissue to remove any remaining cleaner residue.
Dec 08, 2008 | Nikon Normal AF Nikkor 50mm f/1.8D...
Canon PowerShot SD1100 IS Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
